HT hook up question
trubluluc
trubluluc Posts: 2,067
edited June 2006 in Electronics
Crazy....of course, but
I want to run dual sda center channel speakers without running separate amps.
I have a yamaha receiver with pre- outs/ins.
I have a dvd player with a 5 channel decoder built in.
Can I run a pre-out of the dvd player into a Y splitter, into the receiver 's pre-in Mains, thereby gaining two pairs of speaker leads to run the dual SDA speakers.
I am only using the receiver to power the center channels (mains) and the surrounds.
Is there a better way, working only with what I've got ?
thanks,
-Luc
Post edited by trubluluc on
    tonyb Posts: 33,069
    edited June 2006
    The center pre-out on your AVR,you need a spliter,but i doubt your AVR will be able to do it justice with out a seperate amp for the centers.You might
    have a loss in volume in the center,throwing the sounstage out of wack.
    BTW- I would like to power all my gear with flashlight batteries,but......
  • trubluluc
    edited June 2006
    .........it works, but sounds ...very loud
    due to the fact in this arrangement, I now have no volume control as the receiver is essentially an amp, and sending full power to the centers.
    Oh well, seemed like a great idea.
    I guess I could run the center speakers in parallel.
    There is no shortage of power. The RX-V1 throws out 110wpc without breaking a sweat.
    -Luc
    tonyb Posts: 33,069
    edited June 2006
    MISSUNDERSTOOD your wireing set up.You split off the dvd pre's.
    My bad!!!!
    tonyb Posts: 33,069
    edited June 2006
    You can also take 2-sets of speaker cables and plug them into your avr's center speaker post.You might have to boost the center level a tad in your set-up menu.
    Hastey readers......baaaad:mad:
    Apology from hastey readers........goooood:)
    Any complaints about my rude behavior, please send to
    CFRIZZ,she handles all my complaints.{kiddin cathy}:)
