Online retailer for amp kit and patch cable
da5176
da5176 Posts: 42
edited June 2006 in Car Audio & Electronics
What's the best online retailer with the best prices, best quality and best reputation to purchase amp wiring kits and RCA interconnect cables? What are the best brands and what should I look for? Thanx:)
NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS)
Post edited by da5176 on
  • hexon
    hexon Posts: 38
    edited June 2006
    Just look at sounddomain.com or crutchfield.com. Both are excellent in reputation, however crutchfield has better tech support. Sounddomain.com has cheaper wiring kits, I think I got my rockford fosgate 4 gauge kit from them for about 38 dollars with free shipping, but that didn't include the patch cable. If you are looking for good companies go with stinger, rockford fosgate, or street wires. Street wires are a little more expensive than the others. A good amp wiring kit should cost around 60-70 dollars.
    SHIFT_LOUD
    polkaudio db675
    polkaudio db212-2
    Kenwood KAC-9102D 500 watts @ 4 ohms (850 watts @ 2 ohms)
    Sony 444watt amp
  • exalted512
    exalted512 Posts: 10,734
    edited June 2006
    I get all my wiring from www.knukonceptz.com They have some of the best stuff on the market and extremely low prices
    -Cody
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited June 2006
    Totally agree with the previouse recommendation :D....
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
