Avia test disk
dholmes
How do you adjust the surr back spks level with Avia? Its only in 5.1. Also to adjust the sub level you have to match it with the front L&R spk, is there a test tone on the disk to adjust the sub level only? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
There are two ways to do it.
1. If you want to use the AVIA disc do the following
To adjust the Surr. back spkrs temporarily connect it to the surround spkrs output.
Adjust the dist. for surr. back on your pre/pro in your pre/pro setup menu. Run the AVIA test tone & adjust accordingly.
2. If you pre/pro has internal test tone. Run the sweep for your Surr spkrs and note the level on the sound meter. Adjust the surr. back to that level.
I think this is the easiest way.
I had used option 2 to setup surr. back when I had 7.1. Currently i use only 5.1
Hope it helps.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
thanks, Ill try thatMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
