running 4 speakers on 2 channels (2ohm)
gredd
I have an MTX 4 channel amp I just took out of a truck I am selling. In the truck I was running a set of DB components in the doors, and the other 2 channels were bridged for a 12" sub. I would like to install this set-up in my car and run 4 full-range speakers on 2 channels (the other 2 for the sub). My question is about wiring the speakers in parallel so that the amp sees a 2 Ohm load. I know that you should run the + connection from one speaker to the next, then to the amp (same for neg.). But I am wondering if you would get the same result if you just ran both speakers to the amp and piggy-backed the connections to one channel? I suck at explaining - hopefully this makes sense.
gredd, welcome to Club Polk Audio. for better response to your question. you may went to post it in the car audio forums portion of Club Polk instead.
good luck.PolkFest 2012, who's going>?
Thanks for the tip - I'll do that
