Volume Control?
Refefer
Refefer Posts: 1,280
edited June 2006 in Electronics
Hey guys,
I'm looking for a good volume control. Just a volume control. I am helping a friend build a 2 channel system who is looking for a way to control the volume going from his source to amplifier. He's looking for something cheap and only has one source to deal with, so I was thinking that there might be a good component which has only one input/output attached to a high quality dial? However, I don't know of any and am looking for suggestions or other work arounds.
Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
Post edited by Refefer on
  • Frank Z
    Frank Z Posts: 5,860
    edited May 2006
    Why in the world would you (he) want to do that? There is no volume to control from the source. Volume is a function of the amp, it is controled by the preamp.
    F1nut Posts: 51,760
    edited May 2006
    There are some sources (cdp's) that have the ability to control the volume, bypassing the need for an pre amp.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2006
    This isn't really cheap at $250 retail, $150 used when you can find it, but I would consider it good quality as Channel Island makes nice stuff.
    http://www.ciaudio.com/vpc1.html
    If you are going to lay out that much for a passive preamp, I would look into a simple quality linestage active preamp from any of the higher end companies on the used market. More control IMO.
    F1nut Posts: 51,760
    edited May 2006
    Ah, good on ya Dennis.
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    I am truely amazed, Dennis seems to know about every little thing we have questions about. WOW. I think he just sits at home or work all day and browses the internet for audio stuff.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • Gaara
    Gaara Posts: 2,415
    edited June 2006
    When I was looking into this my searches always led me to EVS Ultimate Attenuators. These units are supposed to be the best sounding attenuators out there, but the are no longer being produced. They pop up on Audiogon every once in a while, its sad that Ric Schultz no longer makes them.
    A good alternative that is also cheaper and more ergonomic would be Endler Audio Attenuators, you can get a stereo volume control for less then $100.
    Jared
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2006
    There is also the passive line stage that Zero had a while back. I think it's around $50 or so
    found it: Monarchy Audio Passive
    Creek makes some pieces also, OBH-something or other.
  • faster100
    faster100 Posts: 6,124
    edited June 2006
    The Monarchy was cool and worked but was IMO not that great to look and was something someone could easily do themselves. I have and used a dynakit dsc-1 passive pre.. I know its old but it has only one input and is very small (maybe 5" wide x 8' deep) volume control and balance only basically run from 20 in bad shape to 50 -60 in mint shape.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Refefer
    edited June 2006
    Wow, Many thanks guys. More responses than I expected, and exactly what I was looking for. Thanks again.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2006
    Creek has been doing this idea for quite some time with the OBH-22 and OBH-22SE. I'm not sure what the previous model number was...OBH-12...but it's a helluva lot cheaper than buying a new source.
