Wire Recommendations
psalm10720
psalm10720 Posts: 2
edited June 2006 in Car Audio & Electronics
Does anyone have a site or know where I can get wiring recommendations to wire new polk car door speakers? ie.. should I use metra 10 gauge wire? Monster Cable? Is there a differnece? Is there an ultimate wire gauge and manufacturer to use in this application?
Psalm 107:20 "God sent forth his word and healed them, he delivered them from their destructions."
Post edited by psalm10720 on
  • exalted512
    exalted512 Posts: 10,734
    edited May 2006
    www.knukonceptz.com for all your wiring needs. monster speaker wire is crap
    -Cody
  • psalm10720
    psalm10720 Posts: 2
    edited May 2006
    do you use this brand?
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited May 2006
    I use this brand and will continue to use it from now on.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
    sure do
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2006
    Go to Lowes. They have 14 guage speaker wire. 100' for $25. Cant beat that anywhere and its just as good as the fancy stuff.
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=214940-578-PM62122&lpage=none
  • 1996blackmax
    edited May 2006
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
    you just beat that
    -Cody
  • MacLeod
    edited May 2006
    Yeah but thats 16 guage and after you pay S&H youre over $25. Mine is $25 shipped, 14 guage AND you dont have to wait for it to be shipped! :D
  • exalted512
    edited May 2006
    dont you have some power wire to tape together:D
    -Cody
  • MacLeod
    edited May 2006
    Anything to save a buck! ;)
  • exalted512
    edited May 2006
    ill get that distro block out to you next week. Ive been extremely busy lately so i havent been able to get around to it.
    -Cody
  • 1996blackmax
    edited May 2006
    Well, I would rather have higher quality 16g over run of the mill 14g any day of the week :D
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
    theres no doubt in my mind that knu's 16 has a bigger strand count than that 14
    -Cody
  • MacLeod
    edited May 2006
    Oh please. Speaker wire is speaker wire.
  • 1996blackmax
    edited May 2006
    and speakers are just speakers, and amps are just amps, and hu's are just hu's, and subs are just subs, and sound deadening materials are....... :D
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
    just sound deadening materials?
  • cam5860
    cam5860 Posts: 632
    edited May 2006
    stranded copper wire is all the same there is no difference. People say there is more strands of wire in this brand than another brand it's all bull ****.
  • 1996blackmax
    edited May 2006
    Not all the same is my point.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • 1996blackmax
    edited May 2006
    What's bull? The part about being more strands of copper?
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
    do i win something?
  • 1996blackmax
    edited May 2006
    You win an atta boy :D.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • fish369
    fish369 Posts: 13
    edited May 2006
    I have some Esoteric 12 gauge I had in an old install from fifteen years ago and it looks and feels as good as it did when it was new. It is so soft and easy to work with you can bend it around anything, nice thick insulation that was easy to pull. Hard to beat.
    Fred Fisher
    Pioneer VSX-D912K
    Pioneer DV-578A-S
    Toshiba 6 head VCR
    Polk 6800
    Mitsubishi 65"
  • badboyspack
    badboyspack Posts: 10
    edited June 2006
    12 awg should be fine for door speakers
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited June 2006
    Strand count:
    When compared against the same total wire guage, more strand count only has the advantage of conducting more freely above the 1kHz mark.
    The other advantage is bendability.
    Lower Oxygen copper will be less likely to break with repeated bending (as with door installs) but you will probably wear your hinges out faster. there is an extremely small difference in conductivity that you wont notice.
    Go get cheap wire. It's plain, but it'll do the job. Just get the right gauge for the job.
    -Jerry-
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
