Gainclone done the Wardsweb way
Wardsweb
Wardsweb Posts: 942
edited May 2006 in DIY, Mods & Tweaks
My latest project started almost two years ago. Things got busy, life got in the way and the project was shelved back in 2004. Well yesterday I pulled the parts out and decided to whip this thing out for next weeks audio meet in Austin.
Here is a page I've started on the builtd: Wardsweb Gainclone (WWGC)
Post edited by Wardsweb on
  • amulford
    amulford Posts: 5,020
    edited May 2006
    Very cool. Are you going to put some LED's inside it to get the cool glow like your Champion II?
    What kind of specs will it have? How does the heat get transfered mto the sinks? Did you do the circuit design?
    I love to build things, but my expertise is in a different realm...
  • Wardsweb
    Wardsweb Posts: 942
    edited May 2006
    No plans for lights at the moment, but you never know. The LM3875 chip is rated at 56 watts into 8 ohms, so this is basically a 100 watt amplifier. Building is easy, as you just stuff the boards, add a transformer and chassis. That's basically how it goes. The boards came from BrianGT over at the diyaudio forums.
  • Wardsweb
    Wardsweb Posts: 942
    edited May 2006
  • amulford
    edited May 2006
    very clean looking.
    how is the heat transferred?
  • Wardsweb
    Wardsweb Posts: 942
    edited May 2006
    amulford wrote:
    very clean looking.
    I was pushing it pretty hard last night just to see and it doesn't even get warm. The heat sinks are WAY overkill, but they look cool and make for nice sides to the amp.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2006
    Such talent we have here! Looks cool.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • HBombToo
    HBombToo Posts: 5,256
    edited May 2006
    Very impressive!
    Would this amp be a common ground for use with SDA's?
    HBomb
    ***WAREMTAE***
    F1nut Posts: 51,673
    edited May 2006
    Looks good, Luther.
