sub noise
broker
I have a new rotel rsx - 1067 that I just hooked up this week. I upgraded my yamaha receiver to this rotel and so far it was the best thing I ever did.
I am running 2 polk subs psw 303's. The rotel has 2 preouts for duel subs. I am noticing a slight hiss and popping sound out of the left sub. When I ran the subs off the yamaha I used a y connector and I did not have a problem.
My question is should I go back to the Y connector, or is there a better way to calibrate the 2 subs that are running seperate on seperate pre outs?
Both subs are using the LFE input and I am using thx cables
Thanks in advance from a new guy to the home theater market.
Broker
Anybody who tells you money is the root of all evil doesn't have any
rotel rsx1067 receiver
panamax M5100-EX
55" Hitachi HD
polk rti8 front
polk csi3 center
polk rti4 surround back
polk psw303 (2x)
polk rm6801 back
panamax M5100-EX
55" Hitachi HD
polk rti8 front
polk csi3 center
polk psw303 (2x)
polk rm6801 back
Post edited by broker on
Could be a ground issue?
Are the subs plugged into different outlets?
Is the system grounded?
It is just a thought but when I grounded my system I think it made everything work better. It definatly got rid of a hum I was getting.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Oh and welcome to the club.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
i am running it through a Panamax hometheater power conditioner. That should ground it??? I think??
Thanks againBroker
panamax M5100-EX
55" Hitachi HD
polk rti8 front
polk csi3 center
polk psw303 (2x)
polk rm6801 back -
but is everything grounded?
I ran everything but my cable input through my panamax and I got ground feedback through the cable ground.
Now I run everything through the panamax and ground it all.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
You the man sky nut!! I noticed that one of the subs was not grounded through the panamax? Im not sure how the heck that happened! Thanks for the advice, now it all works perfectly! Thanks for helping the "new guy"Broker
panamax M5100-EX
55" Hitachi HD
polk rti8 front
polk csi3 center
polk psw303 (2x)
polk rm6801 back -
Sweeeeeet.
I love it when I can help.
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
