1080i vs. 1080p
Ethancf
Is there REALLY a huge difference between the two?
THE SYSTEM
Polk Audio LSi25 Mains
Polk LSiF/X Surrounds
Polk Audio LSiC Center
Definitive Technology PowerField 1800 Subwoofer
Parasound Classic 7100 Pre/Pro
Parasound 2205A Amplifier
Pioneer Elite BDP-05FD Blu-ray Player
Monster HTS 2600
Microsoft XBox 360
Samsung PN64D550 64" Plasma
Monster HTS 2600
Microsoft XBox 360
Post edited by Ethancf on
yea. one is interlaced and one is progressive. the interlaced means that there are lines of information going both vertical and horizantal. the progressive means only horizantal (i think).
Not quite. Interlaced means the set displays even horizontal rows at one sweep, and the uneven on the second sweep. Progressive sweeps all lines at one sweep.tecmo04 wrote:yea. one is interlaced and one is progressive. the interlaced means that there are lines of information going both vertical and horizantal. the progressive means only horizantal (i think). -
every other line of resolution, 60 frames per second. Interlaced.
all lines at the same time, 30 frames per second. Progressive.
Can you see a difference? Yes but it depends on the source, size of tv and distance away from it. There's really no way to truly show them both to compare seeing there are no 1080i sets in any of the new fixed pixel TV's as they're all progressive sets. The old CRT tv's that do show 1080i cannot show 1080p. So even though they're similar in ways, you cannot really compare them.Never kick a fresh **** on a hot day.
