DIY Digital coax
steveinaz
steveinaz Posts: 19,545
edited May 2006 in DIY, Mods & Tweaks
After alot of research on digital in general and cable theory for digital transmission, I've decided to build a DIY digital cable using the following:
1. 5ft, Belden Part# 1694A RG-6 coaxial cable
2. 2ea, Amphenol BNC connectors, Part# 31-70000
I'm going with an appoximately 1.5 meter length based on general consensus and info that this length seems to be optimal for digital coax, to reduce impeadence mis-match reflections. The Belden 1694A is top-rated, and specifications are the best to be found for 75ohm RG-6 cable. It has a copper, solid core center conductor (I don't like silver). The Amphenol connectors are the best in the biz, period.
Everything will be crimped (no solder).
I'll post pics/instructions when the parts arrive in case anyone else wants to give it a go...
Cost: $15.50
Post edited by steveinaz on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited April 2006
    Sounds like a worth while project. Let us know how it works out. I'm in a DIY mood myself. Current project is a pair of speaker cables using 10ga wire and the copper shielding from a roll of RG-62 coax. I bought a 800' roll of coax for 6.00. Got to find something to do with it.
  • steveinaz
    edited April 2006
    I got the materials and built the cable this morning. They sent Canare BNC's instead of Amphenol (boo), I prefer amphenol.
    The Belden cable is sturdy; foil and braid sheilding, 18awg solid core center conductor. I had to wrestle with it a little as it's a touch fatter than RG6; but finally got it terminated (I had to adjust the stripping tool dozens of times to get it right). The collets on the Canare BNC are a little oversized as well, but the crimper worked with the RG-6 die in. Probably requires the Canare crimp/strip kit---but I'm not spending $300 on tools to build a $15 cable.
    I'll put it in the system tonight and let it run all week.
  • jm1
    jm1 Posts: 618
    edited May 2006
    Any comments on the cable?
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • steveinaz
    edited May 2006
    I'm a little late reporting back. Built the cable, tested against a DH Labs D-75.
    The D-75 is a little smoother, the Belden more analytical.
