Anyone using the Yamaha HTR-5830
Home Theatre
How did you set up your Lfe settings?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
Not familiar with that unit, but easiest physical connection is the sub output RCA jack of the Yamaha. You run a RCA cable from that to the LFE or input jack of the sub.
The Yamaha will either have selections for a crossover frequency, or a speaker size selection, or both. Generally setting your main speakers to small will cause the receiver to send all the frequencies below a certain point, Yamaha uses 80 and 100Hz a lot, to the subwoofer.
If you have a selectable sub crossover frequency you can fine tune the frequency with that as well. 80Hz is a good place to start.
If you have a variable frequency selector on the sub and are crossing over out of the receiver, just turn it to the highest frequency.
Hope that helped.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
Hey Home Theatre,
I own a Yamaha HTR-5830 as well. My LFE settings are both center and front speakers are set to SMALL. I'm sending all my low frequencies to the sub. Question, is this in reference to the Home Theatre in a Box version? Or do you have your own set of speakers your using?My Living Room 3.1 config:
Toshiba 40RV525U
Receiver: Onkyo TX-NR609
Center channel: Polk CS1
Front L/R: Paradigm Reference Studio 20
Subwoofer: Velodyne DPS-10
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX -
frdranger wrote:Hey Home Theatre,
I am using the CSI Polk Center, Cerwin Vega for my fronts, M30 for my surrounds and a jvc sub from oe of those box sets.Everything I own burned in the fire!!!!!!!!!! -
HT, it would have been helpful to be more specific about what you meant by "Lfe settings". If you mean the LFE level setting, then that usually should be left at the standard 0 setting. The setting can be reduced if the sub is inadequate to handle the LFE sometimes present during movies without high distortion, but hopefully that wouldn't be necessary.
If on the other hand you're referring to the setting that determines what bass is sent to the sub, generally it's best to set that to "SWFR" rather than "FRNT" or "BOTH". Set in that way the sub will receive any LFE that might be present during movies and will also receive sound below 90Hz from other speaker channels set "SMALL". Typically, you should let the sub be responsible for all of the low bass by setting all speakers, including the mains, "SMALL" and not using the "BOTH" setting which would run the mains full-range and have them duplicating the main channels bass which the sub is also handling. -
Yea, definitely let the sub handle all the LFE.My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
When you watch the tv what setting do you have it on.
I use Pro Logic 2 Movie.Everything I own burned in the fire!!!!!!!!!! -
Unfortunately, I do not watch TV with my receiever
. Sorry man. My Living Room 3.1 config:
Toshiba 40RV525U
Rears: None
My Computer setup
