Center Channel Question
I have the LSi/C Center channel and was wondering what should i set this as in my setup, Large or Small? What differences does this make as well?
Polk LSi 15
Polk LSi/C
Polk LSi/FX
SVS Ultra
SVS PB3000
Monolith 15 THX
Denon 3700h "switching to Onkyo rz50"
Monolith 7 AMP.
Polk LSi/C
Polk LSi/FX
SVS Ultra
SVS PB3000
Monolith 15 THX
Monolith 7 AMP.
Post edited by tpeter on
manual says set it to small, I would do this if I were you. Doing this removes the bass from your center speaker.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
yep yep, let the bass go to your psw650.
Less vibration to your tv.
-Luc -
Small - Agreed. If you can adjust the x-over freq., pick 100 Hz or 80 Hz - any higher MIGHT make certain male voices sound a bit thin (a problem I had on my previous receiver).
Doc"What we do in life echoes in eternity"
SVS
