Audiosource Amps?
woodyjacobs
woodyjacobs Posts: 706
edited September 2002 in Electronics
Hey guys. Does anyone have any experience with these Amps? I am most curious about the Amp2. I'm thinking of getting an HK AVR 320 or 520 and using this with the pre-outs for the mains for 2 channel listening and also to run my outdoor speaks. I will probably go ahead and buy 2 so I can use the other for 7.1. I currently have an HK AVR 120 and just need more power...and these things look really groovy (match needle outputs meters)
Thanks!
www.audiosource.net
system 1:
Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
system 2:
XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
2 channel
NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
Post edited by woodyjacobs on
  • TroyD
    TroyD Posts: 13,124
    Not a bad idea.......AudioSource makes decent, inexpensive amps. I'd also consider an AMC amp as well.
    V/U's are the shee-at.
    BDT
  • joe logston
    joe logston Posts: 882
    i got one of there 15" subs, and its not bad at all. they got a 200w built-in amp, good stuff for the money
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • woodyjacobs
    Thanks guys...I'll post if I decide to give 'em a try. And will investigate AMC as well.
    system 1:
    system 2:
    2 channel
  • smglbrth
    smglbrth Posts: 1,497
    I have two of the Amp One/A's. They are both bridged for the 200 watt output for each amp in 8 ohms. While I can't say exactly what the difference is between the One/A and the Amp Two, besides the level meters and the auto on/off feature, they do have the exact same power rating.
    I happen to like them, low profile, clean face, decent power and they don't bust your budget.
    If you do get one, either the One/A or Amp Two, make sure you have plenty of ventilation. Both of mine are set up in open areas, not stacked, and they get plenty warm.
    I purchased mine from audiovideoshopper.com for $180 each and was very pleased with the way they handled the transaction and packaging. They also sell AMC.
    Happy purchasing!!
  • woodyjacobs
    Cool...and thanks for the heads up about stacking...I'll have to figure out how I can avoid that...might be time for some new furniture.
    system 1:
    system 2:
    2 channel
