Center placement problem
comer
I have a problem installing the center channel (CS400i to complete RT2000i and fx/500i) around a big screen RPTV (60"). It's fairly large, so I coudn't put it below the TV, but putting it on top makes the sound to separate from the picture
Even though I slanted it forward on it's shelf, so the tweeter points directly at my sitting position or slightly below.
Any ideas?
comer
Any ideas?
comer
Post edited by comer on
Thanks for suggestion, Kris. I have a Sony and I do have it on the original stand. Putting a stand in front of the TV is not an option - WAF is 0 or below
I am thinking of putting a smaller center channel in the stand below to offset the main center channel and bring the sound down. However, the Polk page for my mains do not say anything about centers smaller than cs400 - that is if they sonically match the rest of RTxxxi series.
Does anyone know if cs175i (the smallest) will match well with RT2000i and cs400i? -
If height is the below restriction, the CS350LS is a lower profile center that will match the 400 tweeter-wise as will the 175.More later,
Tour...
Vox Copuli
Get a center channel stand and put it in front of the TV whenever you watch a movie, then remove it once the movie is over. I do that with my front speakers. No WAF issues if you do that.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Danger there is being too tired to move it one night after an evening of HT.
"I'm tired of this ****... You want it moved? Move it yourself," also is pretty low on the WAF scale...
More later,
Tour...
Vox Copuli
Thanks for replies guys. For now I flipped the center so the tweeter is lower and closer to the screen. Helped a bit, but later I may add a low profile center below the screen as well.
Worth a try... But the 350 does sound different than the 400. I'm sure "ditto" would apply to the 175.
Twin 350's could be your best bet. Here is it's info...More later,
Tour...
Vox Copuli
At least it has the same tweeter... But you are right, it will sound different. The only other realistic option I see is to modify a stand to accomodate a thick center - not a very easy task, but possible.
I have the rt2000p's on each side of my set. I have them working with the cs1000p on top of the set.
I ran a three way splitter from my center pre out to three channels of my amp.
Now my center channel has no seams as I like to say.
In other words my ears do not notice where the sound comes from.
I like this setup.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Man! You have 2000 and 3000 around your TV? sweeeeeeeet
That's 2000 and 1000...
Sn,
Nothing under the set?
More later,
Tour...
Vox Copuli
Is it possible to post a picture of your TV with the center channel located on top? (with the grill cover off, from your viewing position)
I am having a hard time visualizing your problem. (then again, my center is about 7' off the floor...)
What I did with my center on top of my RPHDTV, to get the sound to merge better. Was to move it farther back, so from my sitting position, the top of the tv appears to cut off the bottom of the center speaker.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
How about trying NO center,works well for me.If you can be pleased with that
and the wife too,save the cash and spend it upgradeing something else.:)HT SYSTEM-
lsi 9's -
tonyb wrote:How about trying NO center,works well for me.If you can be pleased with that
I do not recommend not having a center for a good HT experience. I think some of the ideas already given about location and even doubling up will work better for your needs. Either way tell us how you finally solved the problem.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Yes and no,Doc.Haveing gone from a full blown SRT set-up 7.1 system down to a 4.0 have to say I don't miss the center.Voices still sound like they come from the center of the TV.Since his option wasn't wife friendly,just wanted him to try it,think outside the box so to speak.He may like it,maybe he won't.
Doesn't hurt to try,just an option,thats all.:)HT SYSTEM-
lsi 9's -
Tonyb,
My bad. Forgot about the main reason for this thread and that was WAF. You are correct and may be a very viable option.
My apologies.Holydoc (Home Theatre Lover)
Certainly easy enough to try out anyway. Just go into your AVR and set your center channel to none. (rather than large or small)
You don't even have to disconnect anything.
Give it a shot and let us know what you think.
None needed man,just wanted to explain my statement there a bit more.
The wife always wins in the long run,cheers bud.HT SYSTEM-
lsi 9's -
Phantom center was a good thought... Fine for on-axis viewing, not so much for off-axis, though.
comer,
Progress?More later,
Tour...
Vox Copuli
Does the CSi3 or 5 have the capability to mount then to a wall? I only have 49 inches above my Fireplace for TV and Speaker. From calculations, I could conceivbly fit a 50 and the center speaker up there but I'm curious as to if I could acutally mount it on the front of the Frame out for the fireplace.
