Crossover wiring
Landseller
I am installing mmc6500 in my boat, due to the potencial of water spash and very limited space, how far away can I mount my crossover box from the speaker? The distance I would like is 12 feet.
Post edited by Landseller on
I see no reason that you can't mount your crossover in a remote location. What gauge wire were you planning on using?Political Correctness'.........defined
President of Club Polk -
I will be using 16 gage wire, is that enough? Any ideas on better brands such as monster cable?
16 gage should work for you. Due to the distance you wouldn't hurt yourself to go with 14 gage or higher either.
High purity low oxygen copper is a good price vs performance choice. Monster would work. Other brands to look at might be Canare, Cardas, Belden, Liberty, and on the lower price end but still decent quality, Dayton Audio.
Here are a couple links to take a look at.
http://www.ramelectronics.net/html/speaker-cable.html
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=56&ObjectGroup_ID=377
http://www.partsconnexion.com/catalog/wire.htmlThe Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here.
