How to do freq measurements?
Schris22
Schris22 Posts: 983
I always see guys that have freq measurements of their room. I was wondering how you guys did this? what equipment is neccessary and software.
Thanks,
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Post edited by Schris22 on
  • bknauss
    bknauss Posts: 1,441
    edited April 2006
    Rat shack SPL meter, test disc with lots of frequencies, and excel. Take measurements, record the dB and the frequency, make a graph. Other methods might be easier, but they generally require expensive software and equipment.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Schris22
    Schris22 Posts: 983
    edited April 2006
    oh. I always thought that someone had a freq sweep and some microphone with a ratshack meter and somehow recorded anything.
    If it's manual, I guess it'll take a while. I have an avia disk but can't remember if it had a full frequency sweep.
    Chris
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2006
    You can run this free software off your computer with a rat shack SPL meter. I have yet to use it, but it is my understanding that the software plays a tone for a few seconds while the rat shack meter "settles" in on the reading, then the software records it to the computer. After a few minutes you have a generated sweep. I would only use it on a subwoofer though...
    The software is designed to be used in conjuction with the Behringer Feedback Destroyer or or TAG McLaren processors. It's a great tool to have to get your sub dialed in just right.
  • michael_w
    michael_w Posts: 2,813
    edited April 2006
    I use Room EQ Wizard as well. It's fairly hand and easy to use. All you need is to connect an spl meter to your computer's mic in and then use the audio out to your preamp. Not the greatest way because you're chucking a computer in the signal path and using it as a source, but it's good for getting a general idea of the response.
    Pretty much all you have to do is get the spl meter calibrated with the program so that when your speakers are playing a 75dB tone the program sees it as 75dB. Once you have that you hit a button and it does a full sweep (or a designated x hz to x hz) in about two seconds and you have a graph.
  • .Jon
    .Jon Posts: 98
    edited April 2006
    BABY thats a sexy program. tanks for pointing that out. i was planning on getting a spl meter soon, but now i have an easier to use it.
    vsnares
  • tryrrthg
    edited April 2006
    This Page has some nice links explaining how to hook up and use Room EQ wizard, and the BFD.
  • Holydoc
    Holydoc Posts: 1,048
    edited April 2006
    I have a CD full of 1hz steps ( every 10 seconds) from 10hz to 200hz. Along with that high tech stuff, I use SPL meter, EXCEL, and beer. Setting the SPL on a tri-pod in my seat, I run the CD while recording the decibel range within Excel. EXCEL does the work of compensating for the SPL's inaccuracies and plotting out the bass response.
    To run from 10hz to 100hz usually takes me about 15min from setup to plotted graph. Or in layman's terms... a couple of beers.
    Now that I think about it, maybe the beer is the cause of that one null spot in my room. :)
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • Schris22
    Schris22 Posts: 983
    edited April 2006
    Actually holydoc your thread reminded me that I needed to do this for my own room, but I didn't want to hijack your thread so here we are.
    Anyway, Thanks for all the responses, i'm moving back home for the summer so I'll just wait till then to buy the necessary cables and the such for connecting all these things together. I'm sure they are cheap ratshack cables to connect everything.
    Chris
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
  • michael_w
    edited April 2006
    All you need is two cables that go from 1/8" headphone jacks (asuming that's what your soundcard uses) to rca's. I use my laptop, spl meter and a tripod simply because it's easier than using my desktop.
    I'd definatly reccommend giving it a shot if you have an spl meter. It's interesting to see what kind of response you actually have in room. This program helped me point out a null of about 15dB between 55 and 65Hz so I'm glad I took the time to play with it ;)
  • Lowell_M
    Lowell_M Posts: 1,660
    edited April 2006
    Where did you get the CD?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Holydoc
    edited April 2006
    Woo Hoo! I found it:
    http://www.realtraps.com/test-cd.htm
  • Lowell_M
    edited April 2006
    Holydoc wrote:
    Hmm...forgot where I downloaded the testtones from. There are so many places. Then I burned a CD. So that you do not have to search around, I have uploaded them for you.
    http://members.cox.net/holydoc/stereo/test-cd.zip
    Awesome! Thank you!
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Holydoc
    edited April 2006
    a_mattison wrote:
    Awesome! Thank you!
    Look at my post again. I found the website. Now I can get rid of the test tones from my webspace.
