If you had this funky room layout, how would you do your placement?
jrlouie
Okay, so if you had this type of room layout, how would you lay out a 5.1 Lsi setup with an SVS sub?
Note that my couch with end-tables is about 11 feet. I have a love-seat too.
Post edited by jrlouie on
this is just me. how i would do it. or at least try this way out.PolkFest 2012, who's going>?
Is moving an option?More later,
Tour...
Vox Copuli
I used to live in that corner of the county.........too many dirt roads and hills when it snows.:DHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Actually, I was thinking about moving into this placeTour2ma wrote:Is moving an option?
I had an epiphany. How about this...
I'd have to buy recliners, but it would work. -
jrlouie wrote:I had an epiphany. How about this...
Thats about it.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I'd actually go with DB's option...
Mine is set up like jrlouie suggested, the only real problem is that all my front sound comes back at me after hitting the kitchen wall behind me. I don't have the dining room there, just the kitchen. It lowers the amount of sound defanition comming from the rears.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
