How long does speaker wire last?
I am in the process of rearranging my home theater and figured since everything is dissassembled this may be a good time to replace the speaker wire, if necessary. I am currently using Monster cable throughout my system and it is around 15 years old now. Now I know that Monster cable is not thought very highly of on this forum but aside from the personal opinions of the brand itself, could anyone tell me if speaker wire degrades over time and would need to be replaced?
If I need to replace it I will likely go with a different brand but if it will still be ok then I will most likely keep it. I don't hear anything in particular that would be a sign of the wire failing, but since I have been listening to it almost daily for 15 years now I probably wouldn't notice a steady declination of sound quality. Unfortunately speaker wire isn't someting you can 'buy and try', so if I don't need to shell out the money at this time for new wire I would prefer not to. But if I do what brands would you guys recommend at a resonable price? Bearing in mind I don't really need audiophile quality cable that costs $100/10ft.
Any and all feedback is welcome!! Thanks!
Sean
Sean
Post edited by StinkyDog on
While monster is not highly thought of it is solid quality high purity copper, which is what you want if you are just running standard speaker wire.
Generally the wire itself is not going to degrade. The stripped ends of the wire will oxidize some over time. If the wires have a dull look, or even green, where they exit the cable simply cut the bare ends and strip back some more insulation to get clean wire that was protected by the sleeve.
Some people use anti oxidizing compounds on the bare ends of the wire to slow/prevent oxidation. Unless the wire has been exposed to extreme prolonged high temperature or corrosive chemicals the part in the sleeve should be fine.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
Your speaker wire will be conducting electricity long after you enter the "oxygen free" zone....Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks guys. I appreciate the feedback!
Untill you decide that it's the week link and time to upgrade it and buy better more exspensive stuff. Also known as the upgrade bug...TV - Sony 36" KV-36FV27
A/V Receiver - NAD T753
2 Ch Amp - Rotel RB-870BX
CD - Rotel 930AX
DVD/DVDA - Panasonic DVD-A7
Panasonic SACD / DVDA
Speaks,
Main - MB Quart QL S830 4ohm @ 87 DB
CC - MB Quart QL S330CTR 4ohm @ 90 DB
Rear - MB Quart QL S530 4ohm @ 85 DB
Sub - Definitive Technology PRO Sub 100 TL -
Buy new speaker wire. You'll get a better sound. Check out Audioquest Type 4 or Type 6.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
If you are still getting the same good sound out of your speakers that you were getting 15 yrs ago, then there is no reason to change it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Sure it is. What you do is buy it used from places like Audiogon and if it doesn't float your boat, then you can resell it with little or no loss of money.
As for your present cable, if it's the stuff with a clear plastic cover then you need to examine it closely for oxidation, which will appear as a green color.Political Correctness'.........defined
President of Club Polk -
F1nut wrote:Sure it is. What you do is buy it used from places like Audiogon and if it doesn't float your boat, then you can resell it with little or no loss of money.
Good idea F1nut, I didn't think of something like that. I'll have to look around and see what I can find. That way I'll be able to tell if my sound quality has declined.
As far as the cover of the wire, it's the pink cover that is kinda clear. But there shouldn't be any oxidation since it is still sealed within the plastic sheating, correct? -
StinkyDog wrote:As far as the cover of the wire, it's the pink cover that is kinda clear. But there shouldn't be any oxidation since it is still sealed within the plastic sheating, correct?
If there is oxidation at the bare wires, sometimes it can travel a tad under the insulation. Usually not more than half an inch or so, unless you were in an especially moist or corrosive environment.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
Zen Dragon wrote:If there is oxidation at the bare wires, sometimes it can travel a tad under the insulation. Usually not more than half an inch or so, unless you were in an especially moist or corrosive environment.
That's what I thought. The ends will need to be trimmed up a bit though. Thanks!! -
the great cable and wire debate will continue till we're all just dust in the wind many years from now.
As i see it.. some people are very content in whatever brand wires/cables they choose.. why change it out right? Other's like to taste something a little different now and then. and maybe find out that their cable they've been using for 15 or so years.. no longer sounds good. The only way you'd know that for sure is to try out a new different brand cable.
If you like your pizza for instance with sausage every time you eat pizza.. but one day you venture after from your sausage pizza and try hot Italian sausage.. sure it's still sausage, but it's your new favorite pizza.. you will never go back to the regular sausage pizza anymore. once you've had hot Italian sausage.
Point being is.. how can you know if there isn't something else out there better that you may like if you never try it out?PolkFest 2012, who's going>?
No, the M cable with the clear covering is known to have a problem with a reaction between the plastic and the copper wire that causes severe oxidation, that's why I brought it up.Political Correctness'.........defined
F1nut wrote:No, the M cable with the clear covering is known to have a problem with a reaction between the plastic and the copper wire that causes severe oxidation, that's why I brought it up.
Ouch! I'll look it over. Thanks! -
danger boy wrote:...you will never go back to the regular sausage pizza anymore. once you've had hot Italian sausage.
My new favorite line!!! -
danger boy wrote:you will never go back to the regular sausage pizza anymore. once you've had hot Italian sausage.
Wasn't that a Sylvester Stalone line from one of his movies:DThe Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
