CD Players under $1000
crazy
crazy Posts: 443
edited April 2006 in Electronics
What makes a good CD player better than others? I mean, if the laser is reading 0's and 1's and translating them, why do we have CD players than are $100 and CD players that are several thousand dollars???!!!
I'm currently searching for a good CD player to replace my Onkyo Universal player (maybe I'll keep the Onkyo for old times sake) and would like some help.
I've kind of narrowed it down to these 4 given the fact that they're all below $1K and infact most of them are in the $500-$700 range which is a real good buy.
1) Cambridge Audio Azur 640C
2) Music Hall
3) Rotel RCD-1072
4) Rega Apollo
Out of these, I do like the Rega and Rotel quite a bit. Looks-wise, the Rotel looks a lot better than the cheap plastic looking Rega, but the Rega does sound impressive.
Then there's also the Rotel RCD-02 which is going for virtually nothing these days (used) or the Cambridge Audio 540C etc., not to mention the Denon.
Would really appreciate some feedback/comments/suggestions regarding this.
Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes)
Post edited by crazy on
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2006
    The main differences between CDPs, as I understand it, are going to be caused by the DAC (dynamics, noise floor), transport (jitter), and other inline parts such as wiring and caps (noise floor and other subtle differences).
    I would personally lean toward the Rotel RCD-1072 from those you listed. If you can find a good, cheap RCD-02, the differences between the two are very subtle. However, it all comes down to your ear, your room, your associated equipment, and your wallet.
    Good luck with your hunt!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2006
    Add the Arcam CD73 to the list with the Rotel 1072, and Rega. Not a big Cambridge fan myself. MH is ok, but overpriced considering the grey market equivelants out of China.
    Also, the Marantz SA8260 - nothing but stellar reviews (I agree), and being closed out (new & refurb) for 7 or 8 Franklins. SACD is the icing on this already delicious audio cake.
    Cheers,
    Russ
  • crazy
    crazy Posts: 443
    edited April 2006
    Half these CD players are made in China - isn't that amazing?
    Shanling and Music Hall are supposed to share an assemby line. Rotel's are made in China and so are Cambridge Audio (manufactured in China though the engineering is in the UK).
    The Arcam CD73 does indeed have some great ratings but isn't that almost $1500 or so?
    I wonder if anyone on this thread owns a Rega.
    Audiobliss, it's good to hear that the RCD-02 is close to the RCD-1072 since there are a lot of those available for rather cheap these days.
  • RuSsMaN
    edited April 2006
    The Arcam is $699.
  • crazy
    crazy Posts: 443
    edited April 2006
    While we're on the CD topic, I wanted to add that Rotel has released (or is about to release) a new CD player, namely the RCD-06.
    Strangely this is shown on their international website but not the US site.
    http://europe.rotel.com/series06/specs/rcd06.htm
    Also, from what I've heard, Cambridge Audio is supposed to be releasing a new CD player, the Azur 840C to go with their new 840 integrated amps.
  • audiobliss
    edited April 2006
    The RCD-06, obviously, will only be offered in the European market. The RCD-02 has been taken off the US market and is now only offered in the European market.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2006
    I have to go with the Marantz 8260. It has geat redbook sound and SACD as Russ mentioned. The Rotel 1072 is also very nice, no SACD though. And yes, SACD is going to be around a while.
    Carl
  • ckpiv
    ckpiv Posts: 35
    edited April 2006
    I picked up a used RCD-1072 for around $500 bucks and would not trade it. Good solid performance, low noise floor - you will not be disappointed.
    2 ch rig:
    Parasound Halo A21 amp
    Wyred4Sound DAC2
    Audiophilleo 2
    Dodd Audio Tube Preamp
    Parasound Halo P3 Preamp
    Mac Mini + Amarra, Audirvana Plus, Pure Music
    2TB External HD
    PS Audio P3
    Rotel RCD1072 cd player
    Polk SDA-SRS 2.3 Speakers
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    Damn, this decision is getting harder: Arcam with no SACD or Marantz w/ SACD? I really want the Arcam, but the possibility of SACD is tempting.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • crazy
    crazy Posts: 443
    edited April 2006
    Zero - I hear ya. So what you're saying is that the Cambridge Audio won't do justice to my current setup.
    However the Rotel or the Arcam, even though they're in the same price as the CA, is a good buy to go along with my setup?
    I did really like the sound of the Rotel - haven't heard the Arcam yet. I also really like the Rega.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2006
    Everyone should have a universal or at least SACD player, I would mention the Jolida a stellar sounding tubed Redbook player that can be had under 1G.
  • TroyD
    TroyD Posts: 13,124
    edited April 2006
    Ditto big daddy on the Jolida. Haven't hear much that tops it.
    BDT
    F1nut Posts: 51,701
    edited April 2006
    Agreed, for a redbook only player under 1k, the Jolida is hard to beat. You have to change the stock Chinese tubes and I'd advise upgrading the power cord too.
  • SuperDave
    SuperDave Posts: 168
    edited April 2006
    Would you use PCM or analog outputs? Or are all these analog out. Sorry if it is a bad question.:p
    SuperDave
    Yamaha RX-V992 (Center,Rears)
    Adcom GFA-5500 (Main)
    Denon DVD-1920
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Main
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Adcom GFA-5500 (Mains)
    Denon DVD-1920
    Mitsubishi 40" LCD
    DirecTV DVR Whole House
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    F1nut Posts: 51,701
    edited April 2006
    I think what you meant is digital or analog outputs. For more info on PCM look here, http://searchnetworking.techtarget.com/sDefinition/0,,sid7_gci214284,00.html
    You could use either. If you use the digital out, then you are using the DAC in whatever processing device you connect to. If you use the analog outs, then you use the DAC in the cd player.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2006
    Another question on PCM. If you are running your DVD player with a digital coax/optical out, you should use RAW or Bitstream instead of PCM, right?
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited April 2006
    that's a big affirmative
  • SuperDave
    edited April 2006
    In your opinion would the DAC in the yamaha rec or the denon cd be better?
    SuperDave
    Denon DVD-1920
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Main
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Denon DVD-1920
    Mitsubishi 40" LCD
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • audiobliss
    edited April 2006
    Based on the names alone, I would say the Denon CDP's DAC would be worlds better than the Yamaha receiver's DAC.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • SuperDave
    edited April 2006
    So I should use the analog out of the denon to rec instead of the optical cable for 2 channel? I use the optical now..
    SuperDave
    Denon DVD-1920
    Sony XBR 27"
    BrightHouse DVR
    Polk LSi25 Main
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
    SuperDave
    Denon DVD-1920
    Mitsubishi 40" LCD
    Polk LSi25 Mains
    Polk LSiC Center
    Infinity RS1 Rears
    Monster THX Cables
  • audiobliss
    edited April 2006
    To use the Denon's DAC, then yes, use a RCA cable via the analog connections to your receiver. What model Denon is it?
    EDIT - Drrr....it's in your sig! :p nvm
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • SKsolutions
    SKsolutions Posts: 1,820
    edited April 2006
    I shook the magic 8-ball,. . . sacd, dead.
    Consulted the Amazing Kreskin,. . . DVD-A, dead.
    I'm thinking the vinal guys are saner and you all know how weird they are.:eek:
    -Ignorance is strength -
  • Flash21
    Flash21 Posts: 316
    edited April 2006
    I have heard the Rotel 1072 and the Music Hall 25.2. Of those two I preferred the Music Hall, the Rotel seemed too polite for rock/blues such as I like. The Music Hall was pretty interesting...not good enough to spring for the upgrade, but a very strong value at it's price point.
    I would definitely like to audition the Apollo, at least after they get the bugs worked out...
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2006
    I'd roll the dice and take my chances on the Marantz 8260 @$799 from Audio Advisor or $699 from Accessories 4 Less refurbed; either way you can't go wrong.
    Say whatever you like, but it's a tall order to get on Stereophiles "A List" under 3 large.
    FWIW, for a thousand bucks I'd be choosing between:
    1. Marantz SA-8260
    2. CEC TL-51 transport
    3. Rotel 1072
