Looking for head unit info?
da5176
da5176 Posts: 42
edited April 2006 in Car Audio & Electronics
Hey guys, I'm wondering if anybody out there can tell me anything about the head unit in my 06 Toyota Highlander. It's the standard unit they put in the car. What I'm wondering is how much power does it put out? One place told me it was a pretty good unit comparable to around $200-$300 of a new one. Another place told me it was just a plain old stock radio that I would defiantly benefit from replacing it. Does the second place just want to sell me on a new radio or would there be much difference in replacing it. I already replaced the fronts with Infinity components and the back with MTX co-axials. I also added a 12" Infinity sub powered by a 300W Rockford Fosgate amp. If replacing the radio would make a definite difference what would you guys suggest I replace the radio with? My budget would be up to $250 installed. I rarely listen to things cranked up really loud. I want a full range sound that sounds good at any volume. Thanks for any help:)
NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS)
Post edited by da5176 on
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited April 2006
    I think replacing it will give you more tuning options, as well as the ability to plug in other things.
    What do you want out of the HU?
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • da5176
    da5176 Posts: 42
    edited April 2006
    I'm looking for more power if a new HU would give that to me and maybe a cleaner sound. The DVD player plays softer than the radio stations do.
    Polk CS2 (CENTER)
  • 1996blackmax
    edited April 2006
    Are you planning on upgrading later to an amplifier? A HU's built in amp will only give you so much power, nothing compared to an external amplifier. An external amplifier will give you both, more power, and cleaner sound.
    I will say that since you say that there is a mismatch in volume in sound sources, I will throw my HU as an example. Eclipse units allow you to adjust the volume of each source relative to the radio. This way your sound stays constant between sources. That is a nice thing that comes in handy.
    If you really do not want an amp, I would look to see if Panasonic still makes their high output HU's.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited April 2006
    panasonic is going to start using class t amps in their HUs pretty soon. They claim youll be able to run a small sub off of it. Pricing is supposed to be around $500
    -Cody
  • 98thumpin
    98thumpin Posts: 649
    edited April 2006
    but for the good bass, get a real amp
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • iworkfortweeter
    iworkfortweeter Posts: 53
    edited April 2006
    its going to give you better sound quality if you replace it...as previously stated, it'll give you TONS of options that thing doesn't have. keep in mind that may be a double-spaced unit, so either get a double spaced hu, or buy a compatible kit for installing a single unit.
    good luck!
    currently in car:
    '00 Honda Accord LX V6
    AEM V2 cold air induction
    c400.4 amp powering a pair of momo 6500's
    and a pair of momo 6x9's
    alpine monoblock amp powering a jl w3 12''
    custom fab work for tweeters
    jl rca's, dist block and power/grounds
    alpine cda 9857 head
    three ground loop isolators
    ipod integration, all songs at 320kbs
