HELP! low freq hum on the sub
ohskigod
just noticed a low frequency hum on my sub. hums even if i disconnect the subwoofer cable. if i touch the imputs with my finger, the hum diminishes slightly. the volume and crossover settings have no effect on the hum. if i turn the phase control to 0, (all the way to the left), the hum gets louder. if i turn it to 180 degrees, the hum gets much lower in volume (but still there). I changed the power cable with no change. cant be a ground loop since it does it even when disconnected from the sub cable.
please help, this is driving me nuts, do i need a new plate amp?
i use a parts express 250W plate amp (the one without the bass boost i believe) if this helps
desperatly
Lou
desperatly
Lou
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Post edited by ohskigod on
Sounds like the amp has an issue, if it sits their and hums even without an input.
funny thing is, if i jiggle the input jacks, sometimes the sound goes away. wierd. also, if i touch the top of the plate amp, the sound goes away too. ???Living Room 2 Channel -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
WTF???? sound is gone, jiggled the jacks yesterday as noted below, and today, no noise. oh well, i guess i should be happy.
my guess now that it is a ground issue since i was able to touch the amp with my finger in some places (on the outside of course) and the sound went away
friggin wierd!
at least all is well
thanx for the help anyway
I was keeping the subwoofer on the carpeted floor in my apartment. I kept it on a table just to test and its silent now. thats such a relief. -
Sorry I replied to the wrong thread.
I noticed a very low hum from my sub and its silent after I put it on a platform instead of on the carpet. -
ohskigod wrote:WTF???? sound is gone, jiggled the jacks yesterday as noted below, and today, no noise. oh well, i guess i should be happy.
QUOTE]
Definitely sounds like a grounding issue. If jiggling the jacks took care of it it may be a bad shield on a cable or on the jack. If it returns check the shield connections on the jacks internally or with a multimeter. Might check the resistance end to end on the low side of the cable. Flex the cable while taking the measurement and watch for changes in the value.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here.
