Tube re-rolling required with new gear?
Early B.
Early B. Posts: 7,900
edited April 2006 in 2 Channel Audio
OK, so I rolled a few tubes on my Jolida int amp and eventually came up with a very nice combination that I enjoy. Recently, I changed out my speakers. Is there a need to re-experiment with tube rolling due to a change in speakers?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2006
    I would say so. Won't hurt anything.
    But if you like the way the new speaks sound with the gear, well, you may not want to bother. I am so stuck on the Amperex 6dj8 I am using now its going to be tough for me change which of course is limiting my own perspective.
    RT1
  • organ
    organ Posts: 4,969
    edited April 2006
    Yes. I prefer different combos for my Polks and Klipsch.
  • madmax
    madmax Posts: 12,434
    edited April 2006
    Yes, there is a need. There is no way around it. The rolling must begin again.
    madmax
    Vinyl, the final frontier...
  • bikerboy
    bikerboy Posts: 1,231
    edited April 2006
    Hi,
    I have had to listen to all my tube sets again after getting a new used B&K amp. Many of the tubes caused the system to sound too bright with the old amp and now I can listen to any of them and am happy with the changes in sound. Even the Brimars are ok. Couldnt stand them before.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • Normanality
    Normanality Posts: 297
    edited April 2006
    madmax
    Having just acquired a VTL TL2.5 preamp I found the sound to be a bit dark with too much bass. Before I roll in the new Mullard CV4003 and Sylvania 6350's, I need to listen to my setup on my Innersound electrostatic speakers which need help with the bass.
    I never thought about tubes and speaker combos.
    Now I may have to install casters on my speakers :D
