SDA-SRS and CSi5 or LSiC center channel
bongomundo
Has anyone got a favorite center channel to match with the SDS-SRAs? Polk mentions the CSi5 now but I believe they used to recommend the CS1000. Don't know about the LSiC though.
SDA-SRS "The Original"
Acurus 200x3
Yamaha RX-V995 replaces Yamaha DSP A-700
Toshiba SD-9100 replaces Yamaha CDV-1700
Paradigm CC-200
"And when you die, they can bury you in it"
Ruthless People
Acurus 200x3
Paradigm CC-200
Ruthless People
Post edited by bongomundo on
The LSiC matches wonderfully, especially if you have the upgraded tweeters on your SDA's.
Hmm, I was just reading DarqueKnight's post on conversions. I guess I could get the LSiC now while thinking about upgrading my stock SDAs.SDA-SRS "The Original"
Acurus 200x3
Paradigm CC-200
Ruthless People -
The older CS400 or CS400i is a nice match with the SRS's stock SL2000 tweets, but strictly used market here. Sources are the usual suspeects with ebay your best bet.
Shop/ bid wisely and you can get back what you pay for them, if you move on to the replacement tweeters.More later,
Tour...
Vox Copuli
Thanks for the reply. I am leaning toward the LSiC at the moment. I see an eBay CS400i used for $199 today and Acousticsounddesign out of Vegas is selling the LSiC new for $379 on eBay also. IMHO a $200 difference is not enough savings on a used CS400i to warrant going with the older one now that I have read so many positive reviews regarding upgrading the tweeters in the SDA-SRS. But I was wondering until now what center would be a good match for SDAs with stock tweets. Anybody have an opinion of Acousticsounddesign?SDA-SRS "The Original"
Acurus 200x3
Paradigm CC-200
Ruthless People -
bongomundo wrote:Anybody have an opinion of Acousticsounddesign?
I haven't seen a bad report about them yet in a few forums, but you will have no warranty as they aren't an authorized distributor.Harman Kardon AVR-435 Receiver
Polk RTi6 (L/R) CSi3 (Center) RM3000 (SL/SR)
SVS 25-31 PCi (Sub) -
My response may be to late to help. I wrote Polk for a recommended center speaker to match my SDA 1.2TL's with silk domes upgrade. The CS1000P recommended as best, followed by CSi5 as better match than 3rd recommended, LSiC. Forum members have made other recommendations. Though not specifically recommended to match 1.2TL's, read the CS400 sounds as good as the CS1000P if you have a separate subwoofer. Newer model is the CS400i.
I would like input from others that may be using the CS400i with 1.2TL's with silk domes. I have an SVS PB-12 Ultra subwoofer in my system and the 1.2's put out plenty of bass themselves. I am not yet sure of center channel speaker to go with.Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Center: CS1000p Rear Surr.; f/x1000
Parasound HCA-1205A amp; Center & rear
Sub: SVS PB12-Ultra
DVD: Denon 3910
Tuner, FM: Onkyo Integra T-9090II
Cassette: Onkyo Integra TA-2090
VCRs: JVC HD4000U digital, HRS8000U SVHS
Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
Conditioning: Monster AVS2000, HTS5100MKII
