Find out how many watts you use
organ
OK, I got this formula from a different forum. I think it's correct, I'll have to go through my text book to confirm this but I'm too lazy at the moment.
Use your multimeter. Set it to measure AC Voltage. Play your music at reference level and measure the voltage on one of the outputs of your amp (with speakers playing). The voltage reading will fluctuate because music is complex. Then, you take your highest reading, square that, and divide by the impedance of your speakers. There, you'll have your answer in Watts.
I tried this out earlier today. I pushed my rig to ear bleeding levels that I wouldn't listen at and took the measurement and did the calculations.
Well, at the highest peaks, my speakers were only using 5.29W/ch! Effin encredible! And I used 4 Ohms in the formula just to be safe even though my speakers are 8 nominal.
Post edited by organ on
Sorry to hear about your ears...............I hear that Klipsch makes alot of peoples ears bleed.:DHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I like to let them get physical on me but would never let them make my ears bleed:). They know they have to play nice with me or else I'll feed them SS power.
Are you sure your calculations are correct?>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
We've had this discussion a few times, people are generally shocked at how little power they actually consume.
He's running 98db/w speakers. I'm pretty sure he's doing just fine with 5 watts :cool:Polkersince85 wrote:Are you sure your calculations are correct?
I need to get myself a multimeter so I can do fancy things like this... -
You could also get an estimate by putting an SPL meter, one meter away from the speaker, then do your calculations based on the efficiency of the speaker and amplitude shown on the meter.
So, with 90db efficient speaker.
90db on spl at one meter = 1 watt.
93db = 2 watts
96db = 4 watts
99db = 8watts
102db = 16 watts
105db = 32 watts
108db = 64 watts
111db = 128watts
114db = 256 watts
117db = 512 watts -
Yeah, life would be perfect in an anehoic chamber.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
PT,
Double check your numbers. You doubled up on the 8's -
Organ. Your formula is correct. By the calculations you performed you would only have seen 4.6 volts looking at your multimeter and using the 4 ohms impedance. This does seem a little low voltage wise if you were really pushing it.
A digital multimeter may not be fast enough to capture the fluctuations between highs and lows in the audio signal. I suspect you were pushing a little more voltage and power than that.
A peak RMS voltmeter or perhaps a storage oscilloscope would give you a faster capture time on your signal.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
Well, considering his speakers are 98db efficient, at 5.29 watts, he should be putting out almost 105db, ignoring the effects his room would have. 105db isn't too bad for rocking out, I wouldn't think.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
What about the changing impedence of the speaker as the frequency changes. This is a good rule of thumb measurement, but probably not all that accurate. As Zendragon stated the volt meter is probabaly a bit slow to capture the info needed. Neat concept though. And I completely agree the amount of power needed for normal listening is pretty low.
Zen Dragon wrote:A digital multimeter may not be fast enough to capture the fluctuations between highs and lows in the audio signal. I suspect you were pushing a little more voltage and power than that.
I was wondering about the speed. I figured a standard multi-meter or voltage meter would not have the response needed to even estimate the peaks, much less get close. Then again, 98dB is awfully efficient.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I use a McIntosh wiht the famous meters on them. And for music, I've never got it above 5W. Anything above 5W is bearable (not too loud), but too inpleasent. I don't think it's the speakers (SDA 1.2TL's), but the bright room. If I had a better room, I believe I can get them much louder. Having said that, most people would only listen to it at 1W. I know cause I listen to them much louder than other poeple I know.
Yup Yup,
I've got meters running on all my amps, one even has peak hold. Find background fill music under 1 watt, normal listening around 1-2 watts, loud listening 5~10, and then the wall-shaking ear-bleeding levels which I've never been able to go past about 60w (the point where the police are pounding down your front door, since you couldn't hear them knocking over the music).
If you are able, try using a test tone CD, and carefully listen to the point where the shape of the sound begins to noticably distort (400Hz and less). You'll be surprised how low wattage that is. Only a few speaker companies will list the power to distortion ratios. Sensitivity may be 92db/w, but 1% distortion may kick in at 86~89db. -
Power is all about reproducing transients.More later,
Tour...
Vox Copuli
in my system it seems that the more power and by that i mean not just watts per channel but also high current the more effortless the music sounds. having lots of power in reserve is a good thing regardless of how much power the loudspeakers actually see at loud volume levels.thanks....WCW IIITour2ma wrote:Power is all about reproducing transients.Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
QUOTE]
If you can hear the police pounding then there is still room to move the volume up. I never hear the pounding till it's in between songs.
The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
After reading about the delay multimeters have, I decided to try again. This time, I used the loudest passages for measurement.
The test song I used was "Excuse Me While I Kill Myself" by Sentenced. The chorus is the loudest part of the song, had the most consistent dynamics and also the longest, so the meter should have time to catch up. Again, no more than 5.29W/ch. This was loud as hell. The whole house was shaking and I couldn't even stand in front of the speakers because it was painful. Again, I used 4 Ohms for the speaker impedance but I doubt my RF-35's dip that low.
So if I was indeed pulling off 5.29w/ch, that would be around 108db total from both speakers at 1m. This is going by the speakers specs measured in an anechoic room, so it was probably a lot higher than that when room effects are taken into account. It still amazes me how efficient these speakers are.
When I have more time to play around, I'm gonna give it a shot against my LSi9. That should be interesting. -
LOL:D -
With your efficiency it is possible that is all the power you are pushing. What make/model multimeter were you measuring the signal with and what was the reading?
Another method of power measurement is to put the multimeter in series with the positive lead and measure the peak current flowing. Of course you need to be sure the multimeter can handle the anticipated current, and most handhelds are no good over 10A. You just blow the multimeter fuse.
The formula then becomes current squared x resistance (impedance) to determine power.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
A slightly better way to do this would be to establish the level, then swap in a CD with a 60hz sine wave test tone recorded at full volume. That way you could look up the exact impedence (assuming you've got impedence charts) and the multimeter speed wouldn't matter. This would represent the biggest transient that could come through off a CD... just be careful not to melt your speakers.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
unc2701 wrote:A slightly better way to do this would be to establish the level, then swap in a CD with a 60hz sine wave test tone recorded at full volume. That way you could look up the exact impedence (assuming you've got impedence charts) and the multimeter speed wouldn't matter. This would represent the biggest transient that could come through off a CD... just be careful not to melt your speakers.
Excellent idea. A constant test tone would take out all the fluctuations of a musical mixed signal. 60Hz at high power would be a mighty hum. You could go up towards 400Hz as well.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
But who rocks out to sine waves? I like the idea of having a constant instead of keeping so many variables but you'd probably use a lot less average power listening to music despite any big peaks.
This idea might work alright if you measure your normal listeing level with an spl meter and then replicate it with a sine wave but I think if you do it that way you'll be drawing more power and get a higher number.
