Plug amp into switched outlet on receiver?
EricT43
I like my new (to me) Adcom 5300, but the lack of a remote or signal sensing is a bit annoying. I was thinking of plugging it in to the switched outlet on the back of my Denon 3802, that way it'll turn on and off with the receiver.
Any problem with this?
Post edited by EricT43 on
YES! It's a good way to fry both pieces of gear! I'm not familiar with either one. Do they not have 12v triggers?"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
That's not a good idea as the accessory/convenience outlet is generally not intended for something with a high current draw....ala your Adcom. Just leave the amplifier on, it won't hurt anything.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
No, the amp does not have a trigger of any sort. Actually I just looked through the manual, and looks like the switched outlet is 100W max. So that won't work.
Maybe I can plug it into a Clapper? -
That would be cool.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Eric, as you have already found out, it is NOT a good idea. Just leave your amp on all the time. (Except during a thunderstorm.) It's what I decided to do when I forgot to turn my amp on one time too many!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
You could try a smart power strip. I used one with my receiver and amps.
Receiver was plugged into control outlet and two amps into switched outlets.
http://www.bitsltd.net/smartstrip/faqlcg3.htm -
Along with the suggestion above me, you could look for a power strip/power center that has some outlets controlled by a 12 volt trigger.
Russound made a single 12 volt triggered outlet, the ACT-1. It requires 100ma of 12 volt current to trip it though, and your Denon may not be rated that high. I know a 3805 is only rated at 25ma on the 12 volt trigger.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Not sure how that smart switch works?
Anyway, I think I'll go with just leaving it on for now. That method doesn't require any additional spending. -
It supplies power to the switched outlets when it senses a current draw at the control outlet.EricT43 wrote:Not sure how that smart switch works?
It cuts power to the switched outlets when ther is no current draw at the control outlet for a specified period of time. Worked quite well for me, as I had my equipment in a semi enclosed cabinet and was worried about heat build up.
