B&K AV5000 Series I, 105W x 5 amp. Help/questions
GATOR3000
The local shop has a B&K AV5000 Series I, 105W x 5 amp. for sale. The unit is in absolutely pristine condition in box, no scratches, and no dust better than new. I was thinking to get it to power my FL, FR and C.
My question is:
1. Is this a good amp ?
2. Will I be able to bi-amp my fronts and get 210WPC and run the C with 105W and let my Denon 3806 take care of the surround?
3. Would the B&K AV5000 get hot because of bi-amping?
4. Would there be a noticeable gain in this setup?
Present setup:
Denon AVR 3806 Pre
Rti8’s fronts
Csi5 centre
Rti6’s surrounds
PSW505 sub
Any input would be much appreciated.
Gator
My question is:
Present setup:
Denon AVR 3806 Pre
Rti8’s fronts
Csi5 centre
Rti6’s surrounds
PSW505 sub
Gator
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
Original A8T CD
Post edited by GATOR3000 on
I can only answer #2....no it is not 210 watts by passive bi-amping..it is 105w to your the top and 105 to bottom....It will probably sound better than not doing it. However, IMO and experience, 210 watt to entire speaker sounds better than the passive bi-amping you are talking about.System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
2+2 wrote:I can only answer #2....no it is not 210 watts by passive bi-amping..it is 105w to your the top and 105 to bottom....It will probably sound better than not doing it. However, IMO and experience, 210 watt to entire speaker sounds better than the passive bi-amping you are talking about.
Thank for the explanation 2+2. I'm still learning here.
Theatre System 5.1
Original A8T CD
MONSTER CABLE MP-HTS3500MKII Powercentre -
I can say from personal trials, a separate amp makes a world of difference. Your Rti8s and Csi5 will thank you for it.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James
