Subwoofer SPL level?
da5176
I have a simple question for you guys. I have all my speaker levels calibrated to the same SPL level at the sweat spot. The question is this, what do you guys set your subs SPL relative to the rest of your speakers? I'm just curious what everybody else sets their levels to. Mine is set between 10 to 15 higher, is this too high? Sometimes the base is just right, sometimes it seems too high or too low. Thanks for the input:)
NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS)
Polk CS2 (CENTER)
Post edited by da5176 on
I set my levels all the same. Since I use uncorrected settings, that would make my sub about 2-3 db hot when spl's read the same with the meter.
After I set all channels equal with a SPL meter. I listen to some music I like and adjust up or down by ear to get it right. (usually down about 1-2 db)
Once I adjust for music - that is the setting I use for movies and music.
Michael
Edit - as to whether your setting are to "hot" or not - I am sure there is more bass than the director intended, but if you like the sound and your sub will put up with it - more power to you. Thats not how I listen, but its your setup. In your system, its your opinion that matters.Mains.............Polk LSi15 (Cherry)
I also set them all the same but i mostly watch movies near reference levels, and I have a very large room to fill, 26x16 with openings into a 10x8 a 10x12 and
two 10x4. My poor svs does quite a nice job or pressurizing 6080 cu.ft. with less
space or more subs i would run them higher, just because I am a bass freak.dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
I use the same level for all speakers, sub included.
Sorry to get off topic (I try to run them all the same), but of late it seems my RS SPL meter is WAY off on sub levels. When I am running my receiver test tones it will completely drop off and not even register on the sub tone. I have cranked the sub level way up to check it and used my auto calibration feature, plus changed batteries with similar results. Has anyone else had this same problem?
Thanks- GregAVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One -
.... calibrated to the same SPL level at the sweat spot....
I am thinking maybe a portable fan may be good here...or some towels or plastic sheeting...?:D
But seriously folks.......My sub is about 2-3 db hotter than the rest.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
my dou have what in your death star aka the house distroyer aka you have what in your theater is set to 2 db above the rest
Run mine 5+ hotter than the rest on Movies and = (same level on the rest) when listening to music. Be advised, most Music is better with 2.0 GIG. ALSO, it is wise to use THX optimizer and not your receiver test tones freq. Spl must be in 90 when calibrating your sub. There is a link in this forum regarding a device on how to calib your sub, BFD(not sure if the name is right).
search for BFD
GOODLUCKGodspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
I run my mine about 5db hot for everything.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James
