New DVD player suggestions....
shawn474
shawn474 Posts: 3,052
edited March 2006 in Electronics
I have recently begun to experience problems with my Panasonic progresive scan dvd player (not sure of the model number, but I paid about 200 dollars and got it well over five years ago). Considering a budget of 300 dollars, what is the best dvd player to get at this time? Is it worth it to wait for the blueray players and spend more money? I have heard a lot about the "up conversion players", the denons and the oppo dvd player, but what in that price range gives me the best sound and picture quality? I am running it with a sony str-da5es avr. As always, thanks for the input and advice.
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2006
    Panasonic S77?
  • Willow
    Willow Posts: 11,257
    edited March 2006
    The oppo received great reviews for the price and their CS is said to be amazing. I was considering this player. I wanted something to play Divx on. But I found an upconverting divx playing toshiba last night open box for 89$ so I bought it.
    I myself wouldn't buy blueray or any HDdvd player anytime soon, I want then to iron out the crap before I invest.
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2006
    I always recommend Denon. I haven't seen the Oppo in action, yet.
  • shack
    shack Posts: 11,154
    edited March 2006
    Same here.
  • shawn474
    edited March 2006
    Which model number of the Denon would you recommend? I've heard good things about the 2910, but it's a little out of my price range. Thanks again for all the advice.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • peteran
    peteran Posts: 141
    edited March 2006
    If i was you, I would jump into the HD-dvd players. spent 200 more and you wouldn't have to upgrade later.
    http://www.crutchfield.com/S-q1RDCIuQo2N/cgi-bin/ProdGroup.asp?g=279850
    I know the toshiba should be available soon.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    edited March 2006
    Yamaha S-657. Great value. Highest picture quality in this class and SACD - DVD-A compatible. Check some pro reviews in the web. ;)
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • shack
    shack Posts: 11,154
    edited March 2006
    I have a DVD-1910 and like it a lot. The new DVD-1920 looks nice (and is now a true universal player with DVD-A and SACD - if that matters)
    http://www.usa.denon.com/ProductDetails/418.asp
  • Nelson57
    Nelson57 Posts: 190
    edited March 2006
    Shawn, in your price range, I would recommend the Denon 1920.
    Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
    Secondary System: Polk RTi 6 L/R, CSi3, Center, FXi3 x4 Surrounds, Def-Tech Supercube II, Pioneer Elite VSX-23 Receiver
  • dipiazza
    dipiazza Posts: 363
    edited March 2006
    Shawn,
    Ive got the Denon DVD-910, it works great and you can get if refurb most likely for pretty cheap. alot less than 300. I think i paid 130 or something. but its a great DVDP for the money.
    -Jake
    (i'll be visiting you when SB is over)
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • shawn474
    edited March 2006
    Jake,
    Does the 910 support DVD-A and SACD? I would think that if I was to upgrade at this point, I would want one that supprots those formats. Thanks to everyone for the suggestions. Seems like the Denon is the overwhelming favorite.
    Thanks again,
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shack
    shack Posts: 11,154
    edited March 2006
    shawn474 wrote:
    Jake,
    Thanks again,
    Shawn
    No. If you want the Denon with SACD and DVD-A you will need to go with the DVD-1920.
  • aaharvel
    aaharvel Posts: 4,489
    edited March 2006
    Harman's 720p/1080i upscaling players, the DVD-37, or DVD-47 if you want SACD & dvd-a
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2006
    My I suggest the soon to street Sony Blu-ray. Yeah, it'll be a bit out of your budget though.
    I'd wait, within the next month the HD-DVD players will hit the stores and will be between $300 and $400. I plan on buying one as soon as they street.
    If...
    Ron loves a film = don't even rent.
  • dipiazza
    dipiazza Posts: 363
    edited March 2006
    True the 910 does not support dvda or sacd... kinda wish i had one that did. but its only like 100 bucks so what can you expect. heh.
    Dont really know about the 1920, but it sounds great. quite universal.
    -Jake
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • aaharvel
    edited March 2006
    Ron-P wrote:
    woah. Where's the ES moniker?
    that looks SWEEEEEET!
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2006
    Samsung DVD-HD950 (or DVD-HD941). I own 941 and it is awesome!
    * DVD-Audio and SACD support (6-channel analog output in the back for this).
    * Faroudja chipset.
    * Upsampling to 720p and 1080i through component outputs (also has HDMI output).
    Overall, great value for the money for sure.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • *Seby*-Polk-
    edited March 2006
    ohh great picture of that Sony Blu Ray player :cool:
  • polksda
    polksda Posts: 716
    edited March 2006
    You can get a refurbed Oppo from the company direct for $160 + $15 S&H. Carries same warranty as new units. Comes with both a DVI-DVI cable and a DVI-HDMI cable, which is nice. Yes, customer support is about the most responsive on the planet; almost legendary. They release new firmware every few weeks, not just bugfixes, but feature additions. Amazing really.
    I picked one up to use for PAL and non-region-1 discs, since my Pioneer 79avi does not do PAL nor can be hacked.
    With respect to Denon models, depending on your display you *MAY* encounter macroblocking problems. The denon models short of the $3,500 5910 have horrible macroblocking issues, although depending on your display you may or may not ever see them. On my Mits CRT RPTV it was readily apparent. I tried both the 2910 and 3910 and could not view material on either.
    To see how the Oppo fared on scientific tests (with recent firmware it actually bests the $3,500 Denon 5910) see the link below:
    http://www.hometheaterhifi.com/cgi-bin/shootout.cgi?function=search&articles=all&type=&manufacturer=0&maxprice=0&deInt=0&mpeg=0
    That being said, the Secrets DVD benchmarks ONLY deal with scientific tests of the video performance. They test absolutely nothing having to do with audio, build quality, feature set, or ergonomics.
    Still, for $175 delivered, it's hard to go wrong...
    [This assumes you plan to use the DVI output, as it will not do upconversion to 720p or 1080i over component output.]
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    Since your TV is a CRT display I would go with a used Denon 2910 or 1920 and hold out for a while for the HD players until the dust has settled. If you plan on getting a DLP set any time in the near future though, I would not recommend the Denon. Just too many macroblocking issues in my experience.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • shawn474
    edited March 2006
    Hey guys, just wanted to thak everyone for their replies. I am doing my research now and will let you know what I get and possibly give a layman's review. Thaks again.
    Shawn
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
