Ripping Redbook CD at bitrate 320
polkatese
polkatese Posts: 6,767
edited March 2006 in Music & Movies
I've been ripping RBCD using MS Media Player using a bitrate of 320, and then burn it back to a CD, to make a replica/copy. What I find interesting is, I can't seem to be able to notice ANY difference with the original source. From slam, micro dynamic, instrument details, etc, no difference. So, in my opinion, the bitrate at 320 seems to be the optimal bitrate.
Thoughts, opinions, and experiences?
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2006
    320's really high, i use a little less and am quite happy... i think people avoid compression out of principle more than anything else...
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2006
    anonymouse wrote:
    If you are making CD copies, why compress at all? Rip it uncompressed as a .wav with EAC and burn that back to CD.
    Because you can fit 4-5 original CD's into a single 320 CD.
  • mldennison
    mldennison Posts: 307
    edited March 2006
    what type of music are you doing this for?
    i have not done experiments like this but when i have heard differences between compressed and uncompressed it is usually in very wide-range music (classical) and not so much in rock/pop music.
  • bikerboy
    bikerboy Posts: 1,230
    edited March 2006
    Hi,
    I find that so many of the players I would play the disc on are not able to play anything but wav files. So I have used wav files for all recordings. The car, the work, and the portable cd players I use all play redbook only so the debate about the difference in quality isnt an issue because they wont make any sound unless it is a wav file.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • Willow
    Willow Posts: 11,219
    edited March 2006
    I use clone CD and choose the burn on the Fly. I have never noticed any problems
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2006
    It may not be night and day, but I can definitely hear a difference on my wma files ripped at 320 KBps - even in my crappy car system.
    I'm surprised that you can't hear a difference between the original and the compressed, even though it's a small difference at 320 KBps.
    Having said that, I rip all my stuff at 320 into wma and that works fine for the car. Even though I can hear a difference, it's not much and not enough to offset the convenience of having most of my music collection fit inside a 320 cd case. I don't do critical listening in the car, so it works fine for me.
    FWIW, these discs don't get play time in the house anywhere...
  • jrlouie
    jrlouie Posts: 462
    edited March 2006
    I thought when you actually burnt the CD it was just uncompressing the MP3 and putting it on the disc. So, regardless of the bitrate you choose, the same amount of music fits on the CD (X number of uncompressed bytes). Now, if you're making an MP3 disc, that's a different story. Then compression takes a role. Maybe that's what needs clarification. Are we talking MP3 discs or standard copies?
    I too have used 320 bitrate, but I'm not sure I could hear a difference with with 256. Maybe 320 for me was more a peace-of-mind thing. But, if you're keeping these MP3's on your PC, it'll obviously use more space.
    Bikerboy,
    I wonder if your MP3 issue has something to do with a setting within the software that treats WAV's different than MP3's when burning. Things like "closing the disc" and "adding a 2 second gap" and "burn at once" and stuff like that can help or hamper a CDP. I only wonder because I thought burning software just uncompressed the MP3 (like to a WAV) anyway and then used that temp data to actually burn the CD.
    I don't know, just some thoughts.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2006
    I copy original cds onto my hd using Windows Media. It burns onto another cd @ 128 kbps. I have noticed no difference when played on my Rotel CD player.
    If it's a poor quality original it will be a poor quality copy.
  • Willow
    edited March 2006
    ;):D
    Great point
  • polkatese
    edited March 2006
    Great discussions! I guess I am not the only one wondering about this.
    Polkmaniac, I tried to hear the difference, but I can't. I have a pretty decent setup on two channels and HT, but still no obvious difference when I compare it with the originial CD, other than a sense of "I think I hear a slight..." placebo effect, perhaps.
    Btw, I ripped-to-HD-and-burned-to-CD two-step process since I also synch it with my iPod (via iTunes). Most of you know I am a Jazz freak, so I make copy of those albums that I really like, to play on my bedroom (two channels) system, for convenience reason.
    Is there a higher bit-rate ripping beyond 320?
  • jrlouie
    jrlouie Posts: 462
    edited March 2006
    I've never seen anything beyond 320 for MP3, but that doesn't mean there isn't. Not sure.
    Seems like you could just go with WAV format which is uncompressed if you wanted really high bitrate.
  • CrBoy
    CrBoy Posts: 580
    edited March 2006
    I'm pretty sure 320 kbps is the max birate for MP3s...
    I have heard a noticeable difference when mp3s are ripped below 112kbps, especially on the high end spectrum... anything above 112kbps (128, 256, 320) sounds the same to me (maybe my ears are F****d up)
  • Toxis
    Toxis Posts: 5,116
    edited March 2006
    I actually did an AB comparison between 192k mp3's and the original. I personally could hear a difference in the high end and the depth of the music. This was with Norah Jones and her voice changed quite a bit. This was using Klipsch RF7 speakers off a Denon 3806 and a 3910 as the source. We actually had two players and just changed the input on the receiver so it was a fast A-B switch. Not like we took the disk out then put in the other and forgot what the first sounded like.
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2006
    Kind of off subject, but isn't the bitrate of .wav files 1411kbps?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • mldennison
    edited March 2006
    yep:
    44,100 samples * 16 bit * 2 channels = 1411.2 kbps
  • kingsqueak
    kingsqueak Posts: 116
    edited March 2006
    Try VBR (variable bitrate) as well, you can set median at 320 but enable VBR and save yourself some decent file size.
    I tend to use 128 VBR with LAME most of the time, it's better than plain 128 without being too much larger. You get a nicer high end than straight bitrate and the weirdness up high is reduced.
    Harman Kardon AVR-435 Receiver
    Polk RTi6 (L/R) CSi3 (Center) RM3000 (SL/SR)
    SVS 25-31 PCi (Sub)
    heiney9 Posts: 25,412
    edited March 2006
    To each their own but going from 1411 kbps to 320 kbps should be noticeable. I admit if you take a great recording in .wav or.cda which is standard and convert it using the likes of the Freuhauffer algorythm at 320 kbps, it can sound pretty good. But, IMO on a high resolution system you'll notice some differences. There seems to be a tad more glare, less definition and natural decay on cymbals and the lower midrange can sound hollow and thin and the bottom end just rolls off rather than extends. This has been my experience with recordings I am very very familiar with. Personally when I'm making Mp3's for portables 320 is the minimum for me.
    All MP3's are not evil, but they should never be used in place of the real thing in a reference system. You can get away with using them in a portable player, boombox type players, car environment, low quality home gear (HTiB), compliation music for a party or sampling music, etc. Never on a high quality home system or in place of the real thing, like purchasing them thru an on-line music seller.
    YMMV
  • phipiper10
    phipiper10 Posts: 961
    edited March 2006
    Use a variable bit rate at 192 then you are using more or less bits as required by the music or a particular passage. It optimizes sound and size. More bits when necessary and fewere bits if not necessary. No sense in encoding at 320 for a chilled out love song. There wouldn't be enough info to bother encoding that high so you are just wasting space.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
    edited March 2006
    Except the fact that 70% of the music is missing even at the highest bit rate. That last sentence is simply not true and is a gross simplification. Compression in the form of Mp3's is not a good thing, passable for certain situations as I mentioned in my previous post. Let's not get all rosy and happy and start making statements like the last sentence. This is how misinformation is perpetuated and then taken as fact.
  • phipiper10
    edited March 2006
    The intent WAS to oversimplify. I'm not advocating mp3s over CDs. I've had literally thousands of CDS in shn or flac formats to avoid mp3s used check sums etc to insure quality. MP3 is practically profanity in the circles I've been in before. I'm just saying that at 192 VBR for people who do use mp3s very few people will tell the difference. It would be crazy to play at 128 on a true audiophile system for the purposes of critical listening. Hopefully like you said if you are using mp3 it's in your car or while working out etc. With VBR rate you are getting more bang for your buck than straight CBR at the same rate. That was really my only point.
    There may be 70% less information but not necessarily 70% less music to the ears. Nobody would use mp3s if 70% of the music was missing - So if 75%of the music was missing for example the Beatles would sound like Ringo doing a drum solo?. Not really.
    No flames intended.
    edited March 2006
    No flames intended.
    Got it.....I try to be a one person crusade against Mp3's being used in place of regular audio files. Just setting the record straight and wasn't meaning to come down on your post. :)
  • PolkThug
    edited March 2006
    A 320 MP3 CD with 100 songs on it is great to pop in your home system on random play!
  • audiobliss
    edited March 2006
    Zero, have you experimented with .ogg files any? They're supposed to be a great alternative to MP3, too.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BrentMcGhee
    BrentMcGhee Posts: 548
    edited March 2006
    I went back and fourth on this same matter for a long time not to long ago when i was trying to decide what format to rip all of my cd's to to put on my car computer. I tried everything from 128cbr 192vbr 320cbr 320vbr flac ogg wav etc etc. For what i could hear, i heard absolutley no difference between the first set of tests (the 128 - 256 in cbr and vbr) The second half of the test i think the differences were just in my head but i did think i herad som differences (i really need to do this one blind with a buddy so i know if i was actually hearing differences or not)
    I tried flac and did not like it, either i was doing something wrong or that is how a flac sounds. Flac files sounded worse than the 128cbr counterpart, it actually soundd pretty hollow and even had some distortion on the high end??
    For simple ease of the rip and confidence in the fact that i did lose any quality i have started to rip all of my cd's as wav files onto my car computers harddrive. This was alot easier than continueing to debate with myself about wich compression format was better.
  • mldennison
    edited March 2006
    wow brent, i am really suprised by this. i can definately see why there would be differences between the different mp3/ogg formats since they are all in some way changing the output waveform but with flac there really is no difference at all (technically) between it and .wav. i guess i would lean towards somehing going wrong with either the encoding or decoding that you are using (or maybe the player?). the idea with flac and shn is that the original PCM bitstream is recoverable from the file so that whatever is going into your DAC is exactly the same set of bits that you would get if you were playing back a wav file.
    now not that i am going to tell you that you are not hearing differences, just that i see it being highly unlikely that it is the acutal file format that is causing the differences.
    edited March 2006
    Mp3's are subtly different and not everyone can hear much of a difference or cares to hear much of a difference. My only point in discussing Mp3's is that people experiment for themselves and not make blanket statements about them being the same as the original audio file. That's when I fly off the handle many times against Mp3's
    You must have had some issue with your FLAC files as those should have sounded the best. As you know it's a lossless format and for the most part creates the original wave exactly, atleast beyond what myself and most who use it can hear or even measure for that matter. Plus a car environment is not condusive for great fidelity.
    FWIW,
    MP3 is a compression format. It provides a representation of pulse-code modulation-encoded (PCM) audio data in a much smaller size by discarding portions that are considered less important to human hearing (similar to JPEG, a lossy compression for images).
    A number of techniques are employed in MP3 to determine which portions of the audio can be discarded, including psychoacoustics. MP3 audio can be compressed with different bit rates, providing a range of tradeoffs between data size and sound quality.
    ***the highlighted passage is why mp3's should never be used to replace the real thing, psychoacoustic's is an integral part of great sounding music***
    Because MP3 is a lossy format, it is able to provide a number of different options for its "bit rate"—that is, the number of bits of encoded data that are used to represent each second of audio. Typically rates chosen are between 128 and 320 kilobit per second. By contrast, uncompressed audio as stored on a compact disc has a bit rate of 1411.2 kbit/s.
    MP3 files encoded with a lower bit rate will generally play back at a lower quality. With too low a bit rate, "compression artifacts" (i.e., sounds that were not present in the original recording) may appear in the reproduction. A good demonstration of compression artifacts is provided by the sound of applause: it is hard to compress because it is random, therefore the failings of the encoder are more obvious, and are audible as ringing.
    As well as the bit rate of the encoded file, the quality of MP3 files depend on the quality of the encoder and the difficulty of the signal being encoded. For average signals with good encoders, many listeners accept the MP3 bit rate of 128 kbit/s and the CD sampling rate of 44.1khz as near enough to compact disc quality for them, providing a compression ratio of approximately 11:1. MP3s properly compressed at this ratio can achieve sound quality superior to that of FM radio and cassette tape, primarily due to the limited bandwidth, SNR, and other limitations of these analog media. However, listening tests show that with a bit of practice many listeners can reliably distinguish 128 kbit/s MP3s from CD originals[citation needed]; in many cases reaching the point where they consider the MP3 audio to be of unacceptably low quality. Yet other listeners, and the same listeners in other environments (such as in a noisy moving vehicle or at a party) will consider the quality acceptable. Obviously, imperfections in an MP3 encode will be much less apparent on low-end computer speakers than on a good stereo system connected to a computer or -- especially -- using high-quality headphones.
    Good encoders produce acceptable quality at 128 to 160 Kibit/s and near-transparency at 160 to 192 kbit/s, while low quality encoders may never reach transparency, not even at 320 kbit/s. It is therefore misleading to speak of 128 kbit/s or 192 kbit/s quality, except in the context of a particular encoder or of the best available encoders. A 128 kbit/s MP3 produced by a good encoder might sound better than a 192 kbit/s MP3 file produced by a bad encoder.
    It is important to note that quality of an audio signal is subjective. A given bit rate suffices for some listeners but not for others. Individual acoustic perception may vary, so it is not evident that a certain psychoacoustic model can give satisfactory results for everyone. Merely changing the conditions of listening, such as the audio playing system or environment, can expose unwanted distortions caused by lossy compression. The numbers given above are rough guidelines that work for many people, but in the field of lossy audio compression the only true measure of the quality of a compression process is to listen to the results.
    If your aim is to archive sound files with no loss of quality (or work on the sound files in a studio for example), then you should use Lossless compression algorithms, currently capable of compressing 16-bit PCM audio to 38% while leaving the audio identical to the original, such as Lossless Audio LA, Apple Lossless, TTA, FLAC, Windows Media Audio 9 Lossless (wma) and Monkey's Audio (among others). Lossless formats are strongly preferred for material that will be edited, mixed, or otherwise processed because the perceptual assumptions made by lossy encoders may not hold true after processing. The losses produced by multiple stages of coding may also compound each other, becoming more evident when the signal is reencoded after processing. Lossless formats produce the best possible result, at the expense of a lower compression ratio.
    Some simple editing operations, such as cutting sections of audio, may be performed directly on the encoded MP3 data without necessitating reencoding. For these operations, the concerns mentioned above are not necessarily relevant, as long as appropriate software (such as mp3DirectCut and MP3Gain) is used to prevent extra decoding-encoding steps.
    There are several limitations inherent to the MP3 format that cannot be overcome by using a better encoder.
    Newer audio compression formats such as Vorbis and AAC no longer have these limitations.
    In technical terms, MP3 is limited in the following ways:
    * Bitrate is limited to a maximum of 320 kbit/s
    * Time resolution can be too low for highly transient signals
    * No scale factor band for frequencies above 15.5/15.8 kHz
    * Joint stereo is done on a frame-to-frame basis
    * Encoder/decoder overall delay is not defined, which means lack of official provision for gapless playback
    Nevertheless, a well-tuned MP3 encoder can perform competitively even with these restrictions.
    FLAC is distinguished from general lossless algorithms, such as ZIP and gzip, in that it is specifically designed for the efficient packing of audio data: while ZIP may compress a CD-quality audio file by ten to twenty percent, FLAC achieves compression rates of thirty to fifty percent.
    While lossy codecs can achieve ratios of eighty percent or more, they do this by discarding data from the original stream. FLAC uses linear prediction to convert the audio samples to a series of small, uncorrelated numbers (known as the residual), which are stored efficiently using Golomb-Rice coding. It also uses run-length encoding for blocks of identical samples, such as silent passages. The technical strengths of FLAC compared to other lossless codecs lie in its ability to be streamed and in a fast decode time, which is independent of compression level.
    FLAC has become the preferred lossless format for trading live music online. Monkey's Audio and Shorten are frequently used as well, although FLAC files are smaller than Shorten files.
    FLAC is also a popular archive format for owners of CDs and other media who wish to preserve their valuable audio collections. If the original media is lost, damaged, or worn out, a FLAC copy of the audio tracks ensures that an exact duplicate of the original data can be recovered at any time, a restoration impossible from a lossy archive (e.g., MP3) of the same data. The optional creation of a CUE file makes the CD perfectly identical to the original CD.
    FLAC supports only fixed-point samples, not floating-point. This is to eliminate any rounding errors to ensure bit-perfect reproduction. It can handle any PCM bit resolution from 4 to 32 bits per sample, any sampling rate from 1 Hz to 1,048,570 Hz in 1 Hz increments, and any number of channels from 1 to 8. Channels can be grouped in cases like stereo and 5.1 channel surround to take advantage of interchannel correlations to increase compression.
    More specifics on FLAC
    http://www.sweetwater.com/expert-center/glossary/t--FreeLosslessAudioCodec(FLAC)
  • mldennison
    edited March 2006
    h9, thanks, that was very informative, i will have to get through all of that stuff on flac when i get some time.
  • BrentMcGhee
    edited March 2006
    Great post heiny! I really enjoyed it.
    On a side note, i would like to try the FLAC codec again, what programs do you guys use to turn your cd's into flac files. And aso what player do you use to play your flac files?
  • mldennison
    edited March 2006
    for encoding/decoding, i use flac frontend:
    http://members.home.nl/w.speek/flac.htm
    ince and simple, but it does everything.
    i dont really do much playing of flac files, mostly for archiving but when i do i use winamp, although there are probably better players out there these days, i have had winamp forever...
    edited March 2006
    Try here to DL- Flac Front End. This the homepage
    http://flac.sourceforge.net/index.html
    I use Foobar to play Flac files, but there are more complex players out there. Foobar is pretty simple and doesn't have all the graphical info. My brother uses Monkey Media player which has a much more informative display, etc. I've been wanting to DL Monkey Media, but I'm lazy and don't want to take the time to re-configure all my settings. One of these day's I will tackle it.
    Foobar will get you going, but with anything configuration is the key. Mine is a bit more difficult because I'm using an outboard DAC. Setting the player to send a pure digital stream thru the soundcard to the Toslink output took some time and searching to get it set-up correctly. This is why I'm dragging my feet on the Monkey Media player. If you are just using the analog output of your sound card it's probably more straight forward for either Monkey Media or Foobar players. There are others I'm sure.
