speaker wire
hey, what gauge should i use for my rti6s and where is a good place that i could find nice speaker wire?
Post edited by schmilnik on
12 would be more than enough, 14 is plenty. I would say at least 16, unless your going over 20 or so feet, then stick with 14 and biggerLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
I started with some RCA "Digital" speaker wire that was 14 gauge and was $35 for 100 feet. I bought it at Home Depot. The stuff sounded great, and was really cheap too. If you go to a place like that, you can buy good stuff for a good price in bulk, as long as you aren't looking for $100 a foot speaker wire.
Depends on your budget. I got my speaker cables from Cobalt Cables and I am very happy with them for the money.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote:Depends on your budget. I got my speaker cables from Cobalt Cables and I am very happy with them for the money.
True, about the $$ I did use HD cable till I bought some Kimber and have been quite happy with the kimbers. -
Wingnut, to the rescue. You go girl.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Can you tell the difference between Cobalt and say generic speaker cables Wingnut?Home Theater In Progress
Samsung 4272
Denon 3910 Universal Player
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Getting closer to complete!:D -
I'd say Audioquest for the Win, humm.. any of there speaker cables that have DBS in them will do great
If you want to "swim into the fray" a bit, try Audioquest Type 4, Kimber 4TC, or Analysis Plus oval 12. All are a relatively cheap way to hear some better speaker cables.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
