Sonic T as a headphone amp??
AsSiMiLaTeD
Anyone tried this, wondering if it would work...
Post edited by AsSiMiLaTeD on
No thoughts on this, surely someone's tried or at least thought about this...
I think I'll check out Head-Fi and see what I can find - I'll post here with my findings... -
You cannot tie the grounds together because it is a non common ground amp. Therefore to use as a headphone amp you would need a custom 4 wire cord breaking the grounds apart.
hmmm....that sounds difficult...plus I'd need some kind of adaptor to go from the mini-jack on a pair of headphones to the speaker terminals on the back...so that won't work...madmax wrote:You cannot tie the grounds together because it is a non common ground amp. Therefore to use as a headphone amp you would need a custom 4 wire cord breaking the grounds apart.
madmax -
Also, you won't get a very good power transfer with the high impedence headphones. You could couple the output with capacitors but that could cause sonic problems.
