600 rms 2 0hm amp ... what is it when you run two amps?
kenstewart
Ok, I purchased an additional Image Dynamics 8" sub (so two subs at 300rms dvc 2 ohms). Trying to decide between a couple of amps.
http://www.mtxaudio.com/caraudio/products/amplifiers/mxa6001.cfm
- or -
http://www.mtxaudio.com/caraudio/products/amplifiers/mxa4001.cfm
Impedance will be 2 ohms, but what does a 600x1 rms amp produce w/two subs? Does it split the 600 to 300 each?
- or -
Eclipse CD8445 HU
Image Dynamics CXS54 Chameleons component setup
Two 8" Image Dynamics ID8D2v.3 subs
MTX MXA6001 amp for subs
MTX MXA3002 2-channel amp for comps
Accumat and Peel-n-Seal
Stinger and Knukoncpetz wiring
Post edited by kenstewart on
the MXA6001 will give 300rms to each sub, in your case it will be a perfect match (MTX is known for being underrated so each sub will get a lil more than 300 rms).<|>
agreed, that amp is quite respectableIt's not good, very fundamentally simply not good. - geolemon
Thanks Cr ... I've heard a lot that MTX underrates their amps by a bit so do you think I'd be well served by going with the MXA4001? It's about $60 cheaper.Eclipse CD8445 HU
Stinger and Knukoncpetz wiring -
the MXA4001 should put out about 450ish rms bridged... I think the extra $60 are well worth it... remember: do it right, do it once!!!
So true ... ty again for the advice, I'll stick with the MXA6001.Eclipse CD8445 HU
any time bud... BTW I read the other thread and you end up with a sweet set up, enjoy it!!!!
MTX are excellent amps. Built like a tank and putting out tons of clean power.polkaudio sound quality competitor since 2005
I had some for a little while. Strong and clean power, underrated as well.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Most competition level amps are underrated. MTX, Crossfire are and PPI is obscenely underrated! Ive seen tests done on these monsters and theyre putting out nearly double what theyre rated! Ill stick with Crossfire for now tho. They make plenty of different models and theyre all extremely powerful and well built. Ive shorted mine out more times than I can count and have never had a problem with them.polkaudio sound quality competitor since 2005
I would still be more careful. I know my Arc amps could stand that abuse, but I would still try my best to avoid tha.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Hey, maybe you are just trying to get new amps. Too bad your amps are not letting you let them go
. Little tanks man. Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
No, Im just lazy and have no patience. I dont feel like unhooking the battery cable everytime I want to experiment with polarity or tighten down the power and ground screws some. Ive arced out against the heat shield before so big that it left a scorch mark! Amp kept on a singing! So let this be a lesson to you all, NEVER let me anywhere near your gear with a screwdriver!polkaudio sound quality competitor since 2005
lmao ... point taken, Mac doesn't hook up my gear
I'm just real cautious which is why I ask so many questions because I worry about shorting or arcing something and **** up my truck. Eclipse CD8445 HU
