4 subs in one box?
C-Man
OK this may seem like a strange one... I have (or will have) two MM104's, and two Image Dynamics IDQ 10's. I was wondering... both these types of subs ask for roughly the same amount of airspace, .66 and .68 respectively. Could I build a custom sealed enclosure and put all 4 of these woofers in it, running each set off a separate amp?
"The Big C"
Post edited by C-Man on
Persoally I wouldnt do it. Because if you did the sub would beat differently. The m104 might take a lower note to bottom it out, and the other subs might do it at a higher note. So if you went to play them it would just sound crappy, same thing on higher notes, the frequencies are different for each sub.Testing
Testing
Testing -
Yeah, I started thinking about it and you're right. Just lookin for ways to get more bass without spending more money ya know.
Any other idea's would be appreciated. Gracias."The Big C" -
i have 2 different subs in my trunk i have a cheap blue thunder 12 and a kicker xpl there is a big differance in the 2 but i just have a amp for each and i can ajust the gain so they both will be tuned
ya dude, look... iDQ's and momo's dont mix...
here's a bit of audio trivia for you... from what i can tell, the IDQ looks very very very similar in style and design to the polk dx / db subs... they're are differences, but what i am saying is that they're in the same "class" -- they're both 300-ish rms, they're both the same size / depth / material / freq response / box requirement, etc. etc.
if you were mixing those, you MIGHT be able to do it.
But I think this rule of wisdom applies... you can -- with some work and some patience in tuning your system -- run two different brand / sizes / styles of sub in the same vehicle.
But you CANNOT do so iin the same chamber / box. if you buildone box for all those subs, that's fine, but you better have WALLS on teh insdie so that each sub is in its own chamber.
However, i really don't think those IDQ's are going to be able
to take the power that the momo's do... so you'd need to run each pair off a separate amp so taht you can keep the idq's low and run the momo's high.
hey if you wanna go nuts... get 2 more momo's and sell the IDQ's.. then you've got 4 kick-a$$ subs that all eat power and spit out bass like nobody's business...
or... save space... get one ID-MAX 12 and dump 1200 watts on it. then again thats a 400 dollar sub that has a high break down rate.The Artist formerly known as PoweredByDodge -
Yeah, I said , the box would be 4 separate chambers, with one amp running the momo's and one running the others, each amp set at the respective frequencies for the subs. I think I might just sell all my 10's and get a JL 15w3, and just run it off my Alpine MRV-1507."The Big C"
one w3 will not outpush 4 momo's nor 4 idq's even...
1507 is a nice nice nice amp though -- real clean, real poweful.The Artist formerly known as PoweredByDodge
