RT25i tweeter model #s
gacole2000
gacole2000 Posts: 255
edited March 2006 in Speakers
Hello,
I have an odd pair of 25is that have tweeters from the RT25 line (bought that way-long story). Does anyone know the tweeter # for the 25i ?
Thanks- Greg
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
Post edited by gacole2000 on
    VR3 Posts: 29,550
    edited March 2006
    I personally dont, but I can tell you Polks CS will...
    i can though tell you how to change it out...
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2006
  • gacole2000
    edited March 2006
    Thanks for the input. I have dealt w/ Ken many times over the years. I was looking at a set of tri-lams, but wanted the correct #'s before I pulled the trigger. Thanks again- Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
