overpowered speakers...???
sunjai
Hi all
I just wanna know can CSI5 "20w-200w" run on a 120w or 130w per channel receiver???
what will happen in long term?????
thanks
thanks
Post edited by sunjai on
Thats plenty of power for the CSi5. You'll be fine. Thats not underpowering the speaker at all. There should be no long term negative consequences from that combination.
What amp are you planning on using?
BTW, welcome to the forum. -
I havn't plan for the amp yet....
is out of my budget for all the speakers and receiver already......
just planning to hock up with the receiver for now.....
which might be a denon 3806 or yamaha 2600 -
If that yamaha is anything like the Denon, you'll be fine in either situation.
Thx for the reply...
