Newbie -
CHAROB719
Hey
I bought a harman-kardon 240, with 2 ea- monitor 60's and a cs 2 center channel.
My room where my system will be is 13x13, should the monitor 60's be behind me or in front corners? HELP need suggestions.
I'm hoping to make this my surround sound as this is a small room. Is there any other speakers I should get (cost a factor now). this is a 7-1 channel reciever.
What should i use for wiring
and what else should I ask you folks!!!
thanks
rl
thanks
rl
Post edited by CHAROB719 on
It sounds to me as though you have the front stage. Emphasis on front...
12 AWG on them. -
Stay within the Monitor line. Monitor 30s or 40s for surrounds would be a good match to the 60s and CS2. If the wire runs are less than 50', 14 AWG would be OK.NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS)
