ISO: Pre/Receiver with 6ch in and out
Mazeroth
I'm looking for a fairly inexpensive pre/receiver that has 6 or more channel input, that I can also run, at the same time, for a passthru for the output. I just need it to be a volume control for me from my active crossover to my amplifiers.
Thanks!
Thanks!
Post edited by Mazeroth on
ISO?
I'm Seeking Onkyo?More later,
Tour...
Vox Copuli
No, no, no!
I'm So Ornery! -
Would my adcom work, it;s cheap and in good shape. Look up my adcom/amc post.
CRj -
Nope, yours won't work.
Are you still looking for this. I've got an AVR 45 that might work for you. It seems to work great in 2 channel but the prologic and dolby digital fizzle out after a couple of minutes. It seems to be a problem with this model. It has 6 channel in and pre outs. If you think you may be interested I can see if I can test the 6 ch in and outs to see if the signals are getting through. I would need to get $20 plus shipping. Cosmetically it's in good shape and has the remote.
pmlewis wrote:Are you still looking for this. I've got an AVR 45 that might work for you. It seems to work great in 2 channel but the prologic and dolby digital fizzle out after a couple of minutes. It seems to be a problem with this model. It has 6 channel in and pre outs. If you think you may be interested I can see if I can test the 6 ch in and outs to see if the signals are getting through. I would need to get $20 plus shipping. Cosmetically it's in good shape and has the remote.
Damn I'm interested if he's not and I'll be in Chicago in 2 weeksMatthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72 -
PM sent.
Thanks.
