Crossover Frequency = Important
VR3
Yep, I thought Id remind everyone that the point in which you cross your sub over (for music) is very important...
A subwoofer crossed over to high will cause the mids to be muddy and the stage to muddy...
If you think you have this problem, try crossing your sub lower...
I went from 70hz to 55hz
big improvement...
big improvement...
Post edited by VR3 on
What about raising both crossovers for fronts & sub? Raising the fronts to 80hz and subs at 80hz? I feel my subs do a much better job 80hz and under compared to my fronts(R50's).HK AVR 335
Polk R50 fronts
Polk CSi25 center
Polk R15 rear
2 Sony modded subs with 12" Daytons
32" Sharp Aquos
PS2 -
I find 80hz is way to boomy, it is playing to much material. 80hz is recomended for HT, but not for music.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
that is a good point, i will to go and do some more experimentation with that, i have never really dropped it below 80 hz just because i assumed my front speakers could not go that low but i guess it is worth a shot to see if i can get anything else out of them.
