Income tax question about deductions
exalted512
I just got done doing my income tax on turbotax.com. I did first with just entering in the information off of my w2, then i did it again putting my $500 worth of tools i used for work in. No difference. The only thing I can think of is that most of them i only had for the last couple months of the year. Anybody know anything else about this crap? Next time I wont be sitting here for an extra 45 minutes doing deductions when it doesnt even help...
-Cody
-Cody
I could be wrong, but there's a standard deduction- if you don't have anything else and the standard deduction is greater than the itemized one then it doesn't matter.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Correct, if you don't have enough to break out of the "Standard Deduction" it's time wasted. Single its $5000 if under it doesn't matter.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
unless you used them for your business and entered them in schedule c.
makes sense.
I used turbo tax online and was going to get a $161 return. Did it again, for free, using H&R Block's tax cut that i found off the IRS's website, got $355 back. I double checked everything and its all entered in right...
It took me 3 hours to do it on turbo tax finding and entering tools and ****. Did it in 10 minutes...for free...using H&R block and doubled my return...wow.
I believe, as with most itemized deduction categories, e.g., Medical, work related expenses also must be in excess of a percentage of your Adjusted Gross Income.More later,
Tour...
Vox Copuli
Tour2ma wrote:I believe, as with most itemized deduction categories, e.g., Medical, work related expenses also must be in excess of a percentage of your Adjusted Gross Income.
True,
But if he has income from a business he is running then the tools can be deducted from the gross income from the business income. So I believe this isn't under the same Adjusted Gross Income rule.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:True,
That is right. If it is his own business, he can deduct on his Scedule C. If he was employed by someone else, it would be deduction on Schedule A if large enough.Signature goes here
