PSW650 Placement
elsid88
I have a room that is 13' by 23'.
Up front are the RT1000i's and CS400i.(They are set to large)
The sub cable is Monster and is a 12' run from the back wall.
Question, should I have the sub parallel with the side wall out about 10' or so, angled, or further out than 10'? I have moved things around but really am trying to get the optimum placement.
Any suggestions would be appreciated.
It is being driven by the Denon AVR4800.
Hopefully the image below will give you some idea.
Thanks,
Tom...
SETUP
RT1000i's(l/r)
CS400i(ctr)
f/x500i's(sl/sr)
RT35i's(slb/srb)
PSW650(sub)
Denon AVR4800
Denon POA5200
Panasonic RP56
Toshiba 57HX81
Monster HTS3500
Monster HTS2500
Thanks,
Tom...
SETUP
RT1000i's(l/r)
CS400i(ctr)
f/x500i's(sl/sr)
RT35i's(slb/srb)
PSW650(sub)
Denon AVR4800
Denon POA5200
Panasonic RP56
Toshiba 57HX81
Monster HTS3500
Monster HTS2500
Post edited by elsid88 on
Sorry,
I guess the image didn't work.
Tom... -
try 8" to 10' from one of the front cornners put the sub on a 45 degree angle, if this dose not work you got to experiment with the placement, room tune it every room is different. you can put the sub around where you sit and move around the room to where it sounds best that where you put the sub.. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
I've got mine on the side wall, so one sub fires toward the front and one toward the back.
