PSW650 Placement
elsid88
elsid88 Posts: 38
I have a room that is 13' by 23'.
Up front are the RT1000i's and CS400i.(They are set to large)
The sub cable is Monster and is a 12' run from the back wall.
Question, should I have the sub parallel with the side wall out about 10' or so, angled, or further out than 10'? I have moved things around but really am trying to get the optimum placement.
Any suggestions would be appreciated.
It is being driven by the Denon AVR4800.
Hopefully the image below will give you some idea.
Thanks,
Tom...
SETUP
RT1000i's(l/r)
CS400i(ctr)
f/x500i's(sl/sr)
RT35i's(slb/srb)
PSW650(sub)
Denon AVR4800
Denon POA5200
Panasonic RP56
Toshiba 57HX81
Monster HTS3500
Monster HTS2500
Post edited by elsid88 on
  • elsid88
    elsid88 Posts: 38
    edited August 2002
    Sorry,
    I guess the image didn't work.
    Tom...
  • joe logston
    joe logston Posts: 882
    edited August 2002
    try 8" to 10' from one of the front cornners put the sub on a 45 degree angle, if this dose not work you got to experiment with the placement, room tune it every room is different. you can put the sub around where you sit and move around the room to where it sounds best that where you put the sub.
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • fireshoes
    fireshoes Posts: 3,167
    edited August 2002
    I've got mine on the side wall, so one sub fires toward the front and one toward the back.
