Ok Tube guys...need some help
heiney9
heiney9 Posts: 25,432
edited February 2006 in 2 Channel Audio
Sometime in the future I'm going to looking at upgrading and possibly getting some tubes in the mix. I will always probably have a sand amp and the idea is to add some tubes in the pre-amp and Dac area. I found a product, which does both, I like very much just based on what I've seen. Here are some photo's
My big question is can you tell by looking at the photo's if the tubes can be rolled in/out of this particular piece? 2 tubes in the pre section and 2 tubes in the Dac section. I know some AMC products have tubes that are more or less permanent. I want to avoid that with this Monarchy. Just wondering and doing some research.
Post edited by heiney9 on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    The tubes shown certainly look socketed (versus hard wired). What the hell are they? I can find nothing in tube database lookups with the numbers shown on the tubes. Which leads me to guess that, yes, the tubes could be rolled -- but, there may be a very limited range of substitutes.
    Edit: From their website "*Military Grade 6DJ8 used in both the DAC and Line Amp sections (4 pcs)"
  • scottyf
    scottyf Posts: 129
    I don't know that particular piece of equipment, but those look like normal tube sockets which means you can remove them. I can't imagine a piece of equipment that you couldn't remove the tubes since they go bad and need replacement (just like light bulbs!).
    If you can remove the tube, you can roll tubes. You need to find out what kind of tubes (they look like 6DJ8's) they are and try others of that type made by different manufacturers and from different time periods. Each peice of equipment will have a couple of tubes that make it really sing.
    It's kind of like listening to different cables to find the ones that match up best with your system.
    Have fun!
    HOME: VPI Classic/Grado Reference Master, EVS-modified Oppo BP83, Bryston DAC, Counterpoint 3000/SA-100 modified by Alta Vista, Polk LSi15
    TRUCK: Pioneer 8600MP, Soundstream 300SX, pr of Xtant 1001i, Autotek SS490.2, Polk SR6500, Polk MMC6500, pr of Polk MM2084DVC
    SCompRacer Posts: 9,112
    6DJ8 were originally made for cascode TV tuners. It was not originally intended for audio applications. They are low noise and can do a good job provided they are powered properly. IIRC, they have lower plate voltage but higher current requirements, like around 15ma. If tubes don't get the proper voltage or current they need, the sound will suffer. 6EF8, 6DJ8, 6922 and 7308 are all frame grid tubes, but I have no idea what you could roll in it or what the results would be.
    If I ever get my new tube pre, it might have 6EF8's in it.
    F1nut Posts: 51,748
    Some companies use tubes that are hardwired (soldered) to the board. They tend to have very long life spans (100,000 hrs.), so replacement isn't that big of a deal.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Oh yea, those companies gear are used by audio snobs!!:p
    No reason the gear pictured cant have the tubes swapped. I rolled for a while but once you find the one you like, well, I pretty much just stick with that.
    RT1
  • dorokusai
    dorokusai Posts: 25,576
    Make sure you use pliers when removing those tubes....Vice Grips work great.
  • madmax
    madmax Posts: 12,434
    There sure is a lot of sand all around those tubes...
    madmax
    Vinyl, the final frontier...
