How to stream music from XP to HT receiver?
MattN03
MattN03 Posts: 558
What are my options for streaming music wirelessly from my harddrive (XP Home OS) to a H/K AVR 635 receiver? Their within 20' of each other. Any suggestions?
Post edited by MattN03 on
  • bobman1235
    bobman1235 Posts: 10,822
    edited February 2006
    Wirelessly, directly the receiver? FM modulation maybe. :)
    Actually they make networked music hubs that hook into the reciever. Here's a page listing some - unfortunately it only lists the manufacturer websites, which you then have to search to find the actual item. Look to be around 200 bucks in most cases.
  • MattN03
    MattN03 Posts: 558
    Oops, well I guess I actually meant streaming to a wireless hub I can connect to the receiver ;)
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I've used a Linksys wireless Home Media device which has Music and or Pictures from my XP home desktop computer. I can say it works fine happy with it.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • peteran
    peteran Posts: 141
    You can also check out Philips Streamium line.
    http://www.store.philips.com
  • polkatese
    polkatese Posts: 6,767
    I use my XBOX 360 to stream audio from my main PC to HT, via XBOX 360 output. It works great, and SQ is very good.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • hoosier21
    hoosier21 Posts: 4,415
    http://www.slimdevices.com/
    This thing is suppose to be the ****, I have no experience with it.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • phipiper10
    phipiper10 Posts: 961
    In getting a little further away from the original discussion some of the Onkyo receivers hook up to pc's via cat-5 cable. No wireless (interference issues) to deal with. Just a direct network connection to the receiver from your pc.
    I've got... let's just I have many many gigs of music on a hardrive. The convenience is brilliant. Of course there are better ways to hear muic but again the convenience of having that much muic at the click of a button is cool.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • SKsolutions
    SKsolutions Posts: 1,820
    Gotta love that Limewire.
    -Ignorance is strength -
    heiney9 Posts: 25,429
    Check out SqueezeBox II
    http://www.slimdevices.com/pi_overview.html
    My brother has one and it works very very well. He uses an outboard DAC insteda of the one built in, but it works very well.
  • andersonbc
    andersonbc Posts: 9
    I have the AirTunes (http://www.apple.com/airportexpress/airtunes.html) and I love it. The downside is that you have to use iTunes (not a downside for me because I already use iTunes). You can also broadcast to multiple AirTunes if you like to fill the whole house with music. They run about $130.
    PS. You don't need an Apple computer to use these. I'm using a Dell Laptop running iTunes (with the music shared off of another computer).
    RTi10's, CSi5, FXi3's, PSW505
