Polk Cobra Speaker Wire
George Grand
George Grand Posts: 12,258
edited February 2006 in 2 Channel Audio
What does it look like? Flat green and copper braided?
Post edited by George Grand on
  • dorokusai
    dorokusai Posts: 25,576
    Green & Gold wires....litz style, with a clear jacket.
    Polk Audio Cobra Cable - History & Information
  • audiobliss
    audiobliss Posts: 12,518
    Polk speaker wire? Polk made/makes speaker wire? Cool.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • dorokusai
    Past tense....not any longer.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I've had green / gold and red / black.
  • dorokusai
    Was the Red/Black flat?
  • amulford
    amulford Posts: 5,020
    Mine are about 1/4" round round, with clear insulation, The conductors are green and gold.
    VR3 Posts: 29,413
    Did Polk ever fix that blowing up issue? ;)
  • RuSsMaN
    None of mine were 'flat', as in Analysis Plus flat?
    I think Chuck ended up with the red pair, he might have moved them on down the road. Henry has the Green I *think*.
  • organ
    organ Posts: 4,969
    I think I have the red pair from Chuck right now. I have to re-terminate them. I still have to find out how to do it properly. I hear it's a PITA.
    I want to bi-wire using Cobras on the tweets and AQ Type4 on the woofers.
    Remember that the Cobras will blow up certain amplifiers(from what I've heard). It produced a loud hum when I hooked it up to my NAD amp.
  • amulford
    I talked to Ken Swauger about them. He said the problem was with older, less stable sand amps. You won't have any problems with any newer ones.
  • BobMcG
    BobMcG Posts: 1,585
    A picture of MikeMcG's
  • dorokusai
    I would bet that some of the bad reputation about these cables simply came from user error. The wires or colors, need to be seperated at the termination end and one wire wrong would cause a big problem.
