WTB subwoofer
schwerhaiv
I am looking to buy the best subwoofer out there in the 200-300 range. Used is preferred, which is why I posted here. However, should someone want to recommend a good buy on a refurb, etc., please let me know. In particular I see there are Athena subs, Cadence sub, and some other Polk and Velodyne in this category. It will be purely for home theater and purely for lows as I recently picked up a rt20p, cs1000p and fx1000 setup from another polkie. I just feel like I need more bass. In the alternative, I would welcome comments about saving for the 400-500 range subs, as well. Thanks.
Post edited by schwerhaiv on
I plan on selling my sub - its the PSW300 which works quite well. I am getting an SVS PS12 Plus/2 which should arrive next week, or the week after.
I dont have the instruction manual or original box.
Let me know if you are interested.
Thanks !!! -
If you want the best deal you can get and don't want to say "it could go a little deeper or pack a bigger punch" just save your $ and get a SVS. I went with a budget sub then made the move to SVS. Save your $ a few more months and just get the SVS.Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250 -
SVS B-Stock on a PB10-ISD isn't a bad option. A little more than your price, but if you save a few additional pennies you can get into a pretty potent sub for $399. I would look in that direction if I were looking for a home theater sub and not looking to drop a lot.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Thanks, I've also been looking at some larger, older SVS tube subs on audiogon. Some need separate amplification. Do you think I'd be better off buying a new PB10-ISD or a used SVS tube sub?
It is better to save your money and get a better product,I saved up for a Velodyne DPS-10 and when I was ready to buy it I found it at half price.so take your time and get something good. LouMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Hi Joe! I like the SVS. I picked mine up at the factory in Youngstown, Ohio. Nice people, great service. Send them a sketch of your room and they will make a recommendation and not oversell you. They also have some B-stock around.Carl
I know its tough to hear because you may want it "NOW" but as you can see from the posts, better to wait a little longer and get what will do the job the way it should be done. The sub can totally change how you look at your HT. Don't skimp, shop for deals instead.Front
Rear
Polk RT600i
Center
Sub
Receiver
YAMAHA RX-V1400
TV
HD receiver
T i V o HR10-250 -
There's a Velodyne CHT-15 on Audiogon for $440obo. Most people on there are more than willing to negotiate...
Well, I couldn't wait too long. I ended up purchasing a pair of 20-39CS's from the Gon for $515, shipped to my door. One is for sale, but I had to buy two to get the price. I can't really imagine what two would sound like. Anyway, I appreciate all the advice. Thanks again.
