That mystery cable
Polk65
Polk65 Posts: 1,405
edited April 2008 in Vintage Speakers
Something about the cable mentioned in two FM threads (photo 1) bugged me until I looked at the RTA 12 connector (photo 2). It is quite similar, and also appears similar to the outside of gkouvaras's SDA 1's (photos 3 and 4).
Any thoughts ?
Post edited by Polk65 on
    F1nut Posts: 51,695
    edited February 2006
    Hmmmmmmmm???
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Come on Guru, lets have it, whats the deal?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Headline News...................
    Fossil discovery indicates experts don't know all they thought. Missing link?
  • Polk65
    Polk65 Posts: 1,405
    Found another...
    Remember our buddy in Colorado that parted out the SDA 1's last year?
    http://www.polkaudio.com/forums/showthread.php?t=30454
  • dorokusai
    dorokusai Posts: 25,576
    Do you see a pattern here? It's still 99% unuseable.
    It's the same termination used on RTA12's for the crossover assembly.
  • Dennis Gardner
    The pattern is that Polk has always used whatever parts they had available on the market for their models until they needed a larger run than the existing inventory could support, or issues with design required change. Its called evolution.
    This is found on all levels of industry, when inventory over/underruns require change in the model run.
    We just shouldn't be trying to discredit sellers on auction sites for what we don't have full knowledge of ourselves.
  • dorokusai
    The pattern is the model number, early SDA1. The tweeter is a notorious, common variation amongst Polk's, as the documentation for the early stuff is all over the place(e.g. RTA12). This interconnect is just a red herring.
  • hoosier21
    hoosier21 Posts: 4,415
    I gotta say, I just learned something.
    Interconnect cable types:
    1. Blade-Blade
    2. Pin-Blade
    3. AI-1 (pin-blade)
    4. Ken S's homebrew AI-1 (blade-blade)
    5. Now this RTA12crossover connector, SDA cable.
    Anymore?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Dennis Gardner
    Don't forget Raife's Vampire 5way and XLR editions. :D
    SDA Upgrade Thread.
    F1nut Posts: 51,695
    Russ, I'd have to agree with what Mark said, "It's still 99% unuseable."
  • hoosier21
    Not sure what either of you two mean by that, the photos look like the connector was factory installed, the cable matches, what is unuseable about that? Am I missing something here?
  • Dennis Gardner
    It just won't fit anything but those few models. 99% of the SDA line uses other types.
  • hoosier21
    Well maybe that's what they meant, but big effing deal it won't fit 99% of the SDAs out there, it looks like there was SDA speakers made that this cable will fit.
    Jesse posted a big warning on the FM that "This is NOT a Polk Audio SDA cable." http://www.polkaudio.com/forums/showthread.php?t=37926
    Not blaming Jesse for posting the thread, as we all thought when we saw a connector that was not "blade-blade" or "pin-blade" , that it was a hack job, something "some idiot" did to the speaker.
    Well it looks like to me there are photos showing this type of connector and this type of cable WAS used by Polk.
    This thread was started to kind of clear the air, that there seems to be an early version of the SDA cable, to me it has done that.
  • Dennis Gardner
    Is this what happens when we assume?
    F1nut Posts: 51,695
    Agreed. Another part of Polk history has been unearthed.
    F1nut Posts: 51,695
    Thanks to Steve for uncovering this mystery.
  • RuSsMaN
    Hilarious.
  • Polk65
    Polk65 Posts: 1,405
    I started this thread hoping to learn if this was a genuine cable and it appears that it was used prior to the blade/blade cable.
    The one thing these speakers share in common is that they are all SDA 1's. These came out around what, 1981/1982 ? That places these right around the production time of the RTA 12's.
    Here are a couple more. I might add, that if it was not for the fact that some recent photos appeared with close-ups I would never have made the connection.
    edit: I moved the three rear photos below.
  • Dennis Gardner
    The carpet in the middle photo screams bell bottoms and disco balls. :eek:
  • Loud & Clear
    Loud & Clear Posts: 1,538
    It was assumed that the guy selling was guilty of passing off a hack job to an unsuspcting public. It seemed a fair assumption at the time. Ultimately, it appears as though that has been disproven, and that the gentleman in question was simply offering up for sale a genuine Polk SDA interconnect; albeit for a limited potential clientele.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
    F1nut Posts: 51,695
    Here's the deal, you didn't know, I didn't know. Steve did some digging and thanks to him, now we all know. I would rather be wrong about something like this than see a fellow Polkie get ripped off. You didn't seem to care about anything except for not having something you didn't like being posted in the FM. So, let's have it, what's the deal?
  • RuSsMaN
    blah blah blah.
    You'll argue about anything Jesse. Do whatever you have to, post whatever you have to, for your ego to stay intact - that's all I am concerned with anymore.
  • Polk65
    Polk65 Posts: 1,405
  • Polk65
    Polk65 Posts: 1,405
  • Polk65
    Polk65 Posts: 1,405
    This is a later model with the inter connect in the same location, but with a blade/blade cable.
  • Polk65
    Polk65 Posts: 1,405
    Who can spot what else is different with the later version?
    edit: No more nagging please! There is nothing new about Polk doing things differently during product runs.
    Jesse did the right thing warning members (new and old) with the knowledge that was known at the time.
    There have been several hack jobs using xlr cables...
  • dorokusai
    Big deal it won't fit? It might be a big deal if it doesn't fit what you own, and you bought it under the assumption that it would eh? The Ebay advertisement doesn't specify a model and is at the very least, misleading. The associated model(s) are ancient and if they haven't made it to the graveyard or dump, it's borderline amazing.
    The linked historical thread and pictures were all but forgotten until now.
  • madmax
    madmax Posts: 12,434
    Oops... :o
    madmax
    Vinyl, the final frontier...
    F1nut Posts: 51,695
    RuSsMaN wrote:
    blah blah blah.
    I'm not the one attacking or agruing about this topic. I'm glad that the correct info has come to light, too bad you don't feel the same way.
    Oh and Russ don't kid yourself, when it comes to egos, no one's is bigger than yours, period.
    Now bugger off.
  • RuSsMaN
    Thanks for validating my point, I knew you couldn't resist.
    Cool, we found out what it is, great, I'll sleep better tonight knowing that.
