Best subwoofer config. for wrangler yj
Stroker
I have a 1988 Jeep Wrangler that is used for show and various events. Well I am a polk momo fan and I went to Tweeter and got yanked they built a rear firing box with 2 ten inch momo's that did'nt fit right and sounded like 1980 archer sub's.. I made them take it out. I want the best enclosure and subs that will sound great all around and hopefully with the top off. Basically I want some help with a box , subs and amp combo .. Everything else is Polk . I can fabricate with metal and great with electrical but suck at woodworking.
Any help would be great i just dont want to waste anymore time or money.
88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Premier 860mp 140 & 200 amp altenator
MMC6500 driven vy c300.2
MMC690 driven by c300.2
2-MM2104's driven by c500.1
Post edited by Stroker on
Also I listen to Disturbed, Metallica, and but when my girl is with me I listen to Rap and club.. Looking for all around I guess.. Also I have a 200 amp divorced altenator just for audio.. So I am very power hungry88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
2-MM2104's driven by c500.1 -
I have no idea what an archer sub is, or what it sounds like, but my guess would be bad... lol. Now do you want someone to build it for you, or are you asking for help building one yourself? Im trying to get the right idea here
Picking ones nose signifies a strong sense of self discovery
System in the works:
PP 6V6 with 12ax7 pre ~ 20 watts
15" Jensen MOD 8ohm ~ 97db SPL
DiMarzio HS3 and/or Tone Zone S -
Its going to be hard for us to talk you thru a box build to custom fit your YJ without being there so I highly recommend you take advantage of one of your local shops. A locally owned shop will have better people with more experience and knowledge and can build you something the exactly meets your budget and SQ needs.polkaudio sound quality competitor since 2005
Ok I tried tweeter and got yanked. LOL archer is radioshack brand . But Iwas looking to see if anyone had good luck with premade jeep boxes built for polk subs. Also is down firing the best way to go. and the best sub & amp combo for my jeep.88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Provided the box is well made (i.e. NOT plastic) and has the proper interior volume, a premade box will work just fine.
Downfiring is a good trick to get some more output out of your sub. The trade off is a bit of clarity tho.
As for amp/sub combo, if you want a pair of 10's get the MM2104 and a single 500.1. Perfect match.polkaudio sound quality competitor since 2005
The best 10 to go with momo wise..88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
dual or single voice coil which one should i get.88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Get a pair of MM2104's single voice coil powered by the 500.1polkaudio sound quality competitor since 2005
cool thanks bro...88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Tell ya this setup slams it's hiney off lol.. I ran as told 2 mm2104's powered by a c500.1 2 mmc690 6x9's powered by a c300.2 2-mmc6500 powered by a c300.2 premier 860mp . today had the doors off had just about everyone i came near jaws dropped. They could'nt beleive the clarity and depth i had going on. Stopped by a local high end custom shop the guys where all over it wanting to know everything said they never heard a jeep come out like that.. Thanks Macleod for the assistance . My chest and back is still numb. LOL88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
LOL! Glad you like it bro! Welcome to the sickness!polkaudio sound quality competitor since 2005
def sick 100% I'm polk'n all my rides LOL..88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
