Carpet spikes
Drumingman
Drumingman Posts: 348
edited February 2006 in Speakers
Do you use them?
I'm wondering if I should use them.
I guess the only raise the speakers 1/2 off the floor.
Any advice would be helpful.
Thank you
Post edited by Drumingman on
    F1nut Posts: 51,687
  • ward91
    ward91 Posts: 338
    i use spikes on my home made sub.
    never used it without so i dont know the diferance
    whan i put my missions on stands compared to the floor there is adefinate difference (i even put my chin to the floor so that i was at the same hight.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • steveinaz
    steveinaz Posts: 19,545
    I like how spiking tightens bass, I take it a step further and put clay tile on the carpet, then the spiked speaker on the tile.
