How to test a blown sub
maperez
I know there is a way to test a sub with a 9 volt battery. Can anyone explane
how?
how?
Post edited by maperez on
yep - you hold a lead from the each terminal of the sub to the appropriate terminal on the battery... basically hooking the sub up to the battery instead of the amp...
you don't want to hold it on for too long, all you need to do is tap it, and if the sub is at least marginally functional, it'll 'pop'... you can also test it by gently pushing down on the center of the cone, if it makes a scratchy noise, that's bad...It's not good, very fundamentally simply not good. - geolemon
of course, if the VC has shorted, that would be a BAD thing to do...It's not good, very fundamentally simply not good. - geolemon
You dont have to use both wires. Simply touch the positive lead of the sub to the positive terminal of the 9v battery. If the cone moves out, its wired up correctly and working. If it moves in, its wired up out of phase. It if doesnt move, youve got problems.polkaudio sound quality competitor since 2005
if u can play a cont sine wave of something around 40hzELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
um... was there an actual answer in this response to a dead 7-week-old thread?It's not good, very fundamentally simply not good. - geolemon
dont think soJohn Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
MacLeod wrote:You dont have to use both wires. Simply touch the positive lead of the sub to the positive terminal of the 9v battery. If the cone moves out, its wired up correctly and working. If it moves in, its wired up out of phase. It if doesnt move, youve got problems.
Only use one wire?
To only one side?
Please explain -
no, you have to have the complete circuit, mac was talking crazinessIt's not good, very fundamentally simply not good. - geolemon
I figured so...
But you never know.... more people have Tesla coils than you think! -
HiPerf360 wrote:?????????????????????
Only use one wire?
To only one side?
Please explain
Hell, I dunno, maybe Im wrong. I tried it once several years ago and Im 90% sure I left the negative speaker wire hooked up to the amp and just touched the positive speaker wire to the positive terminal of the 9V. I do remember there wasnt a "pop". The cone moved out and stayed out for as long as I held the wire to the 9V.polkaudio sound quality competitor since 2005
perhaps, for whatever reason, the grounds were close to each other?? i didn't think this could happen, but i'm not positive...It's not good, very fundamentally simply not good. - geolemon
i just tried it with some speakers with both wires it went "cpop" then thats it .
wont that doo.
if its practical play a sine tone as its realy easy to detect anything thats wrong.
i half blew the bass unit in my missions i hardley noticed it i first got suspicios playing some madonna. but it was verry hard to pick out untill you play a cont sine wave then it was verry obvious.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
neomagus00 wrote:perhaps, for whatever reason, the grounds were close to each other?? i didn't think this could happen, but i'm not positive...
Hmmmm, thats bugging me now. I know for a fact I did it but Im not sure anymore how I did it.
can you replicate it? i'd try it myself if i could access any of my wires without contorting my whole body into my trunk...It's not good, very fundamentally simply not good. - geolemon
well if the negative was hooked up to the amp then it was grounded, there it would work
you can also hook up a multimeter to it, if it doesnt read around 4 ohms if its a 4ohm coil, probably be a bad thing
exalted512 wrote:well if the negative was hooked up to the amp then it was grounded, there it would work
Ha! I knew I wasnt imagining things!polkaudio sound quality competitor since 2005
duh, but you didn't say it was hooked up like that :rolleyes:It's not good, very fundamentally simply not good. - geolemon
The way I tested my blown sub driver from my old M&K...
I took it outside and stomped the living crap out of it and tore the VC out...god I was mad at that thing...
UGH- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
neomagus00 wrote:duh, but you didn't say it was hooked up like that :rolleyes:MacLeod wrote:I tried it once several years ago and Im 90% sure I left the negative speaker wire hooked up to the amp
perhaps i misinterpreted... this is the visual i got from mac's statement:It's not good, very fundamentally simply not good. - geolemon
Right, because thats what I was talking about!!polkaudio sound quality competitor since 2005
don't go sticking subs on batteries... jesus...
**** christ....
get an ohm-meter (little 10 dollar voltmeter thing from rat-shack - has an "ohms" setting)... put it across each voice coil of the sub... if its 8 ohm voice coil it should read somewhere between 7 and 9... if its a 4 ohm coil.. then 3 to 5... that's DC resistance, but it'll tell you if the coil is fried or not.
then... as long as you get resistance... (now you know it wont destroy an amp)... throw it in an appropriate sized box -- or something close -- and hook the **** up... listen to it... hear scratching, it's busted... former's screwed up... sounds good, then it's probably fine.
that's the extent of testing i'd do.
i still do push on cones sometimes, but when you get to more expensive subs with more precise builds... then pressing on a cone (because we're human and never press perfectly straight down) can scrap a sub on ya. and ya i've done it before.The Artist formerly known as PoweredByDodge -
-Cody
The amp is connected to the - of the car battery, not the - of the 9v
Now if you connected the - of the 9v battery to the chassis them yes it might work but if you just take a wire from + of the 9v battery and connect it to the speaker you will get nothing as you have not completed a circuit for the 9v battery. -
PoweredByDodge wrote:don't go sticking subs on batteries... jesus...
**** christ....
How do you think the VOM measures resistance? -
volt/ohm meters measure resistance by placing a voltage across the two leads (red and black... test and common) it then monitors current output through the line and does the simple math.
... a 9 volt is fine. but a 9 volt "home battery" for lack fo a bettery term, isn't going to hurt anything... its maximum current output is pitifully low. go sticking a sub on 12 V car starting battery and you could start problems.
however thats just one half of the reason not to sue a battery.
the other half is that 9 VDC is often not enough power to make some subs move. low impedance coils coupled with heavy structured woofers and you'll never get enough current out of the battery to make it go anywhere.The Artist formerly known as PoweredByDodge -
a nice AC ripple makes subs dribble.. LOL . shoot it with 110 then you'll know it's bad..88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Premier 860mp 140 & 200 amp altenator
MMC6500 driven vy c300.2
MMC690 driven by c300.2
2-MM2104's driven by c500.1 -
... 110V AC wall output juice is what is used to break in some subwoofers. the IDmax dual 4's are broken in by stringing the voice coils of 2 subs together in series and plugging them into the wall. smaller subs... string enough of htem together and u can dothe same... wall power isn't bad at all.The Artist formerly known as PoweredByDodge
The thing I used the 9 volt test for was to check polarity.
When I first installed my front and rear speakers in my Ram and wasnt 100% sure Id done em in phase and so rather than pull everything out I stuck the + speaker wire to the + of the 9V and was able to tell without having to pull the door panels off and speakers out and all that crap.polkaudio sound quality competitor since 2005
