Outlaw m200 monoblock amp
DC80
DC80 Posts: 11
edited February 2006 in Electronics
I am on a budget, and have found a couple of Outlaw m200's for around 300 for two. Do not have much knowledge with amps. Will these add decent power to my two rti10's. The rest of my setup is an onkyo803, csi5 center, a pair of monitor 40's for surround. and a 10in dps velodyne subwoofer.
Post edited by DC80 on
  • shack
    shack Posts: 11,154
    Yes.
  • dkg999
    dkg999 Posts: 5,647
    $150 each is cheap if they are of recent vintage, ie. less than 3 yrs. old. The warranty is 5 yrs and is transferrable if you have the original purchasers name and address. Outlaw doesn't track them by serial#, obviously technology eludes their customer database skills. So verify that you are buying from the original purchaser, or can get the original purchasers name/address if they are less than 5 yrs. old. They are built like tanks! Outlaw is great on customer service even if you bought them used. Be aware they do have a higher noise floor than an Parasound, Adcom, or even the Outlaw multi-channel amps. It's not a problem for HT, just be aware you will hear more hiss if you put your ear up close to the speaker. I am running 6 M200's in my HT. Make sure they have good airflow around them and enjoy!
    DKG999
  • DC80
    DC80 Posts: 11
    This person tells me that they bought them in 2005, and warranty is still good. Thanks for the advice.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Yeah, I'd buy them on the lineage of the line alone. Designed by one of the big guys from GAS and SAE. You can do your homework, and read for enlightenment.
  • DC80
    DC80 Posts: 11
    I bought two monoblocks for my two rti's, and I now am wondering if I should get a third for my csi5. I read that I may not get the correct sound if I don't have my entire fronts hooked up to amps. Do not have the amps yet but are on the way, so I can't listen to the difference in sound at the moment. Any Ideas.
  • ohskigod
    ohskigod Posts: 6,505
    dont panic until you hear it. its an upgrade to consider down the road, but I would be surprised if its some kind of emergency after hearing the set up. just calibrate like usual and you should be fine.
    of course, if you can get another monoblock for the same price, then go get it, but if you have to get it new, then wait a while and see first
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • dkg999
    dkg999 Posts: 5,647
    With the load taken off your receiver with the two main channels using external amps, you should be OK on the center. On the other hand, if you can get a 3rd M200 for the same price, you will never get a much cheaper upgrade to an external amp for the center.
    DKG999
  • audiobliss
    audiobliss Posts: 12,518
    Glad to see you bougth them. That's a steal! I would wait and hear what the setup sounds like wiht just the mains amped before buying a thrid. Yeah, amping the center would be nice, but calibrate your system with just the two and see if you like it. If so, you're good to go.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • scubamike
    scubamike Posts: 60
    Recalibrate before you listen. I made the mistake of upgrading from an Adcom gfa 5500 to a 5800 without recalibrating and blew one woofer in my csi5. Now that I have my 5800 running my rti 150s and my 5500 split and running my csi5 I couldnt be happier. That is until I find another 5500 to run by rti 100s for my surround. Good luck and I'm sure you will be happy.
  • DC80
    DC80 Posts: 11
    Ok I hooked my m200 to to my rti 10's, and they sound great. But the problem that I am having now is that the csi5 does give out sound that the two rtis. I tested the center by hooking it up to one of the monos, and the sound was much cleaner and clearer. I have tried to tweak the settings on my reciever in order to get it to match but have had no luck. I have been looking everywhere on line for a used m200 , and am having no luck. I have found marantz ma-500 and ma700 between $110 to $235 online. This is between the price range that I can afford right now. Would either of these be a good choice for the center or are their other monos amps in this price range that would do a good job. Or should I just save up and buy a new outlaw 2200.
  • Frank Z
    Frank Z Posts: 5,860
  • adam2434
    adam2434 Posts: 995
    Yep, if you haven't already, you will definitely need to recalibrate your channel levels to get equal output for all channels.
    With my separate amps for my front L/R, I had to take them down about 5 dB to get them calibrated to the rest of the channels. For example, when I ran my auto-calibration, it set the center to -1 and fronts to -6 because of the higher output with the separate amps. Without the separate amps, the auto-calibration would set the front L/R to around -1 or -2 (due to similar sensitivity of front and center speakers and equal power to all channels provided by receiver).
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • Early B.
    Early B. Posts: 7,900
    I had a Marantz MA700 on my center channel that sounded a bit cleaner than the Outlaw monoblocks, IMO. Either the Marantz or another Outlaw would be good options.
    "God grooves with tubes."
  • wingnut4772
    wingnut4772 Posts: 7,519
    I agree...an Outlaw may be better though to keep consistent but it would probably be ok either way.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • DC80
    DC80 Posts: 11
    Thank you again for the info. Will definately recalibrate the speakers, and if that doesn't work will get another amp.
